Removing the Dash trim in an LNF
So I know there are other threads that show how to remove the plastic, and I understand how to remove it, but on the LNF, I'm having issues removing the 2 plastic pieces around the steering wheel. Especially the one on the right with the traction control. When you remove it, the wiring and plastic are still in the trim, and I can push the button through, but its going the wrong way when I push it, so i'm not able to pull the trim off completely. Can anybody help?
There is a how to on it in my carbon dash thread.
But from wut I remember with doin mine. I used a small hobby screw driver and bent the plastic clips back slightly holding the buttons in and pushed the buttons to make it slide out. Obviously disconnect buttons from wiring
I got it, finally. I broke the clip holding the wire into the button. For some reason, the Traction control wire clip, just did not want to come out. But I got it, Sprayed em all black, now i'm just waiting for my black oem head unit and HVAC to come in, and ill be done
patooyee
Oct 1, 2015 01:07 PM
Delta coupe
Sep 30, 2015 08:11 AM
