Removing the Dash trim in an LNF
Old Jul 18, 2013 | 04:47 PM
GotDatSlowBalt's Avatar
So I know there are other threads that show how to remove the plastic, and I understand how to remove it, but on the LNF, I'm having issues removing the 2 plastic pieces around the steering wheel. Especially the one on the right with the traction control. When you remove it, the wiring and plastic are still in the trim, and I can push the button through, but its going the wrong way when I push it, so i'm not able to pull the trim off completely. Can anybody help?
Old Jul 18, 2013 | 04:50 PM
GoodLuckBro's Avatar
Can't you just pull the plug out then push the button through?
Old Jul 18, 2013 | 05:05 PM
andrewcarr1993's Avatar
Yeah it's annoying to get the plugs out with how short the wires are but it's doable.
Old Jul 18, 2013 | 06:36 PM
Melon's Avatar
There is a how to on it in my carbon dash thread.
But from wut I remember with doin mine. I used a small hobby screw driver and bent the plastic clips back slightly holding the buttons in and pushed the buttons to make it slide out. Obviously disconnect buttons from wiring
Old Jul 18, 2013 | 11:35 PM
How do you remove the wires from the button? I tried, and for some reason, now the lights won't come on ;(
Old Jul 19, 2013 | 01:10 AM
I got it, finally. I broke the clip holding the wire into the button. For some reason, the Traction control wire clip, just did not want to come out. But I got it, Sprayed em all black, now i'm just waiting for my black oem head unit and HVAC to come in, and ill be done
Old Jul 19, 2013 | 11:06 AM
Melon's Avatar
Should send them in for carbon fiber...
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
Delta coupe
Sep 30, 2015 08:11 AM
