retro build
Old May 12, 2011 | 06:51 PM
heathkidder's Avatar
retro build
so my lights finally came in the other day along with the retro kit. still waiting for another set of lights to arrive to paint and install should be a few more days
but till then i am in the process of painting the shrouds and putting the halos on which were a bitch the mini shrouds have no room on the back to put holes at all. here are a few pics
next up is painting the shrouds but if any1 has the buyhids.com kit chime in
cause for one i notice only one relay which is normal for the newer lights cause my old ones had two.
also on the passenger side of the relay it has a ground, high/low plug and another plug that idk what its for, i mean i no that sumthin needs to plug into the main harness thats connected to the car but that plug looks like the one that plugs into a ballast ??
more pics will be up in a few days
Old May 12, 2011 | 07:14 PM
Cobalt08LS's Avatar
on the relay the blue plug plugs into your driver headlight harness. than you ground the black to the bolt under the headlight bracket and the positive goes to the fusebox post.
for the pass side all you have to do is plug the relay in and ground it. the blue connector stays unplugged.
i said the same thing and was confused.
Old May 12, 2011 | 07:18 PM
ok so leave the blue plug unconnected but what about the other plug
so what plugs into the plug beside the blue connector
and where does this plug go to this is the pass. side of the relay
Old May 12, 2011 | 07:23 PM
TommyP's Avatar
AWD > FWD
Yes, that other connector on the passenger side goes to the ballast. You might have to make a longer ground wire, I had to do some tricky wire routing to get mine to reach the fender bolt
Old May 12, 2011 | 07:28 PM
one is a ground one is high/low but the other one should plug into the car part of the harness but doesnt look like itll fit
then what plugs into the connector in the first pic?
Last edited by heathkidder; May 12, 2011 at 07:28 PM. Reason: Automerged Doublepost
Old May 12, 2011 | 07:39 PM
so what does the connector in the 2nd pic go to i no its a hid ballast plug but how can that be whenn the hid bulb plugs into the ballast?
Old May 12, 2011 | 07:58 PM
LS6Rally's Avatar
you need to put the factory harness on your pass side, the HID bulb plugs into the ballast, the balast then plus into the New harness. and you need to ground the pass side. the small black connector with two wires is for the High beam solenoid.
the blue 9007 connector doesnt plug into anything on the pass side.
Old May 12, 2011 | 08:01 PM
yeah got it figured out now thanks.
its alil different than the other set i had
Old May 12, 2011 | 08:03 PM
LS6Rally's Avatar
you had the G1/G3 set before? thats what i was selling, you will be 10X happier with these Morimoto H1's!
Old May 12, 2011 | 08:05 PM
oh ya i no i will lol and yes i had that shitty setup
Old May 12, 2011 | 08:14 PM
Cobalt08LS's Avatar
u dont have the part of the harness that pluggs into that piece? it should be on the stock harness if thats what your using
mine is from buy hids and its a revised stock harness since the wires had to be switched around.
Old May 12, 2011 | 08:20 PM
mkulrey13's Avatar
You will love the setup. The output is nuts!
Old May 12, 2011 | 08:22 PM
your just confusing me lol i got it figured out.
mike these damn halos are a pain in the ass to get on btw
Old May 12, 2011 | 09:29 PM
mkulrey13's Avatar
There easy! but ive done 15+ sets lol
Old May 12, 2011 | 09:32 PM
how is it easy lol there is like no room ti put two holes the backing on the shroud is small flat lip.
is there sumthin im missing lol or any helpful tips
Old May 12, 2011 | 09:33 PM
see how small the lip is on the back theres like no room the shroud about cracked on the end where the holes are cause its so close
Old May 12, 2011 | 11:36 PM
Cobalt08LS's Avatar
my bad dude haha
Old May 12, 2011 | 11:38 PM
no problem just a few diff. things with this kit compared to my other one
Old May 13, 2011 | 01:40 AM
MastaShaKe_88's Avatar
click
Old May 13, 2011 | 01:50 AM
DiabeticKripple's Avatar
im still having problems with my relay harness. i dont know where it plugs into what. its a female plug and the hid one is female too
Old May 13, 2011 | 01:54 AM
driver side relay
there should be the blue connector
positive
ground
high/low
connector to ballast
pass side.
ground
high/low
blue connector on pass. side you dont use
also the plug on the bulb that normally runs to the ballast you dont use either
Old May 13, 2011 | 02:25 AM
My harness doesn't have the blue connectors like in your pic above
Old May 13, 2011 | 02:26 AM
lol then ur screwed. let me see a pic of it ...is it for retros or for 9007 hids?
Old May 13, 2011 | 02:31 AM
H7 4th gens
I think this is how I have it now
Both ballast wires are connected to the hid connectors and the hid power is somewhere, and turn signals and high beams on the stock harness. I think I'm missing a plug somewhere that's connected but can't remember where it comes from. But I have the harness for my fogs too which isn't being used
Old May 13, 2011 | 02:35 AM
i no nuthin about gen 4s id just have to see all the wiring to help im sure some1 with gen 4s could tell u more thou
