retro build
Old May 13, 2011 | 02:39 AM
DiabeticKripple's Avatar
Just thinking about it, the bulbs had spade connectors on them, which I plugged into the stock piece. so maybe they plug into the harness instead
Old May 13, 2011 | 02:48 AM
heathkidder's Avatar
lol maybe looking at wiring is so confusing but once u start piecing it together is simple atleast for me.
Old May 13, 2011 | 02:53 AM
I had it pieced together the night before, but it just wouldnt work
Old May 13, 2011 | 02:54 AM
hmm if u want my help post pics of the relay harness and the plugs on the headlight im sure sum1 will chime in on ur thread thou
Old May 13, 2011 | 02:57 AM
I can't take my headlights out for at least another week. So I hope someone can help me
Old May 13, 2011 | 03:02 AM
well tomor the list consist of
adding more holes to the 2nd shroud
paiting the shrouds white
and possibly putting the halos on
i gotta work so not much will get done ill post a few more pics
Old May 15, 2011 | 01:46 AM
quick pic of the shroud i finished. been busy with other ppls lights lol
Old May 15, 2011 | 02:56 PM
JimmiLS05's Avatar
You only need one set of wires from the bulbs correct? You can cut the rubber grommet off so you can slide the bulb holder on or am I wrong again?
Old May 15, 2011 | 06:38 PM
the bulb has like 2 or 3 wires. the projector has a wire and the halos have 2.
you dont use the bulb holder "black piece" for retros
Old May 18, 2011 | 12:56 AM
finished up the shrouds finally after getting some free time thurs or fri they should be done hopefully
Old May 18, 2011 | 06:00 PM
  #36
LS6Rally's Avatar
Looking good man, are the Housing white or black?
Old May 18, 2011 | 06:24 PM
  #37
tyler41390's Avatar
i believe he's doing black
Old May 18, 2011 | 09:07 PM
  #38
mkulrey13's Avatar
your box is full cant PM you..
Old May 18, 2011 | 09:52 PM
  #39
black housing with white shroud sry mike its empty now but i got it figured out
Old May 19, 2011 | 12:26 AM
  #40
more pics plan to take the lights apart tomor.
Old May 19, 2011 | 01:12 AM
  #41
Cobalt08LS's Avatar
looking goood
Old May 19, 2011 | 01:16 AM
  #42
i honestly think puttin those on was the hardest lol rest should be cake
Old May 19, 2011 | 01:18 AM
  #43
btw heath, i got the harnesses working. one plug from the harness goes into the ballast, while the other goes where the ballast wire would go into the bulb
Old May 19, 2011 | 01:20 AM
  #44
yeah i seen that the relay goes to the ballast instead of the connector on the bulb it just is left there lol thanks thou
Old May 19, 2011 | 01:37 AM
  #45
ssblackstealth's Avatar
corn gas ftw....
finish these!!!! so i can decide if i want you to make me some lol
Old May 19, 2011 | 01:49 AM
  #46
oh you no you do but if u want halos itll take me longer lol if not i could do it in a day if i wanted but iv been fixing my tail lights and i sold 4 sets of black painted lights so been doing those as well tryin to work a real job lol and do my retros
Old May 19, 2011 | 05:33 AM
  #47
mkulrey13's Avatar
looks good. If i sell my current setup i may steal your black/white combo :P
Old May 19, 2011 | 08:57 AM
  #48
lol understandable mike. what do you actually have as it is btw? and i plan to paint the shroud white as you can see and housing black but leave the turn signal chrome cause i have switchbacks and they just look better that way IMO alot of ppl black them out but i try to be diff. lol
Old May 19, 2011 | 10:02 AM
  #49
06cobalt racer's Avatar
looks good!! finish them so we all can see!
Old May 19, 2011 | 10:05 AM
  #50
should be done 2day or tomor
