Roll Cage
Old Sep 24, 2009 | 12:05 PM
pykie's Avatar
Roll Cage
Just wondering how many users have a cage in their balts?
and did you make it or were you able to buy one pre bent and so on?
also i would like to know if it has the door bars, as well as a harness bar, and is it still able to get people into the rear seats?
or does it make it so you cant have rear seats?
and what site did you buy it from?
Old Sep 24, 2009 | 12:09 PM
MikeyB's Avatar
I have one in my car, i built it, the way its set up, i dont have reseats, it bolts to where the rear seat latches are
My harnesses are then bolted to the floor, where the rear seat crossmember is.
My cage allso has a harnessbar
Check my past postes, you will see the thread i made
Old Sep 24, 2009 | 01:25 PM
pykie's Avatar
What did you use for pipe?
and did you buy the pipe from a local shop? or did you get it from internet.
and why didnt you fallow thru up front?
Old Sep 24, 2009 | 01:39 PM
northvibe's Avatar
Here is his rollcage
https://www.cobaltss.net/forums/appearance-48/new-mod-roll-cage-179050/
REMEMBER though that is not a racing spec cage. That is just for looks.
Old Sep 24, 2009 | 01:42 PM
spike's Avatar
https://www.cobaltss.net/forums/showthread.php?t=179050
Old Sep 24, 2009 | 03:17 PM
pykie's Avatar
ya i seen his cage, i want one for race specs but would like to keep the rear seats. so i was gonna have the cage go down the "C" piller into the trunk.
Old Sep 24, 2009 | 03:24 PM
northvibe's Avatar
what do you need a cage for? you have 217whp, so you wont be in the 10's on a drag and on a road course you are in a stock/street class that wouldnt require a cage. Do you need a harness bar?
Old Sep 24, 2009 | 06:34 PM
pykie's Avatar
i make 217 whp at 8 psi, im building the motor this winter and upgrading to a GT35R and looking at runnin 20-25 PSI
you add the math
Old Sep 24, 2009 | 06:36 PM
northvibe's Avatar
you add the math
I graduated coollege, I dont do math anymore. I have no idea what a gt35r has to do exactly with a roll cage...but which kind of racing are you going to do?
Here GMPP did a build on a roll cage
Part 1
http://gmperformancedivision.com/con...t_Rollcage.pdf
Part 2
http://gmperformancedivision.com/con...e_-_Part_2.pdf
Old Sep 24, 2009 | 06:42 PM
SS/SCking's Avatar
Please for the love of god put a real cage in it if you going to do it at all!!!!!!! S&W makes good cages that will pass tech if welded correctly. Here's a link......
Old Sep 24, 2009 | 06:55 PM
leviticus88's Avatar
http://cobalt-addiction.com/interior.htm
This link sells some cages^^^
Havent ever seen one in person and I'm not sure if thats what you would need?
Old Sep 25, 2009 | 07:58 AM
pykie's Avatar
Part 1
Part 2
1/4 mile drag racing.
GT35R ate about 20 PSI should be around 450-500 WHP
yes i am fully built now too.
Seen them before too, but the pics i seen before were just the cage doesnt show them in the car
thanks i like the look of that cage. i just shot them a e-mail about it.
Old Sep 25, 2009 | 09:24 AM
northvibe's Avatar
A real cage needs to be welded to the frame. Check that gmpp roll cage install out and see if a shop will do it.
Old Sep 25, 2009 | 11:30 AM
MikeyB's Avatar
If you want a race spec cage, you cant have rear seats, no one will get back there and that would be dangerous for them
I used 1 1/4 1020 steel, solid and hollow. Made a huge difference to the way the car handled.
And you will have to weld it to the floor, so you either need to know how to weld or know someone that can. The reason i didn't weld mine to the floor is because when i sell the car, i cant have the cage in.
RaginChopsuey
Oct 27, 2015 01:27 PM
Tupp
Sep 30, 2015 08:18 PM
Tupp
Sep 29, 2015 11:07 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
Builttss
Sep 22, 2015 12:42 AM
