Roof swap with sunroof?
Old May 3, 2012 | 07:11 PM
Slobalty's Avatar
I have an ls which doesn't have a sunroof. If I found one with a sunroof in a junkyard, is it possible to simply swap roofs, headliner, and wiring?
Or do the windshields have to come out?
Old May 3, 2012 | 07:16 PM
TommyP's Avatar
AWD > FWD
it's nowhere near simple. The roof is tack welded in.
Old May 3, 2012 | 07:17 PM
n0xid's Avatar
Heh, going to be a bit more then the windshield. Good luck?
Old May 3, 2012 | 07:24 PM
Daly's Avatar
To weld in a new roof you need to remove the front windshield and rear window. The simplest way to go is to get an aftermarket sunroof, it'll be cheaper in the long run. Even if you get one of the more expensive ones. By the time you remove the windows, remove the roof, weld in your new roof with the sunroof, paint the roof, reinstall the windows, and wire it all you to work, I would bet you would be in the $5-6k area if not more.
Old May 3, 2012 | 08:00 PM
breds2k's Avatar
aftermarket sunroofs are $1000 at the local shop i use. Pretty good deal, its exactly like oem. One touch open/close, tilt as well and a sunshade if you want it.
Old May 3, 2012 | 08:14 PM
Slobalty's Avatar
Ouch, didn't know it was in there like that. I know some cars you can just take them off and replace with cf ones etc.
I'll just go with an aftermarket once I get the cash. Thanks.
Old May 7, 2012 | 01:13 PM
07cbaltLS's Avatar
Just curious what junkyard you found it in? I noticed you're from PA too..
Jan 12, 2016 12:01 AM
ThoR294
Oct 4, 2015 08:44 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
