?'s about carbon fiber trunk
Old Jul 30, 2010 | 07:20 PM
kevinj4891's Avatar
im sure this has been answered before, but im at work and dont always have time to look...
i was wondering about the best quality / best fit of a carbon fiber trunk and where i should buy it? i've heard there are a lot of fitment issues, and i dont want gaps or a leaking trunk (its always sunny hear, but washing my car...)
i probably want an OEM style hood, but may think about scoops/vents. i live in Southern California and will probably have to pay a boat load for shipping, but thats to be expected. any help would be greatly appreciated
Old Jul 30, 2010 | 07:39 PM
Blown07SS's Avatar
It will always have a fitment problem mine was good a little high on driver side but not much. But leaking I never had that problem I had vis racing
Old Jul 30, 2010 | 07:45 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i have VIS. it doesn't fit perfect and it leaks from the reverse lights. note: with VIS you have to drill your own holes and the trunk has to be modded for everything to fit
Old Jul 30, 2010 | 07:48 PM
EXsoccer1921's Avatar
pm'd
Old Jul 30, 2010 | 07:52 PM
Projekt's Avatar
How did you fix your vis? mine is still fucked up on the driver side
Old Jul 30, 2010 | 07:54 PM
BLAZIN07SS's Avatar
I'm too JDM for you
let me see a pic of how it fits. there are only a couple things you can do to make it fit/align
Old Jul 30, 2010 | 07:58 PM
kevinj4891's Avatar
what do you mean you have to drill everything? i don't need a spoiler, but i'd imagine everything should be set to transfer lights, latch, key, etc. why would i have to drill all of that?
Old Jul 30, 2010 | 08:01 PM
BLAZIN07SS's Avatar
I'm too JDM for you
because it doesn't come with those holes opened. most people say that the trunks were marked with the holes to drill, mine didn't so i had to eyeball everything.
-reverse light mounting holes need to be drilled
-reverse light center hole needs to be opened up with a dremel
-trunk lock opening needs to be opened up with a dremel
-drill holes for third brake light
-dremel out the opening for the third brake light a little
-locking mechanism holes need to be drilled
Projekt's Avatar
explain these things, i shall get picture at some point
Old Jul 30, 2010 | 08:08 PM
Blown07SS's Avatar
Yea I had to cut out a Lil bit on my trunk fir the third brake light and key hole but nothin serious.
Old Jul 30, 2010 | 08:34 PM
kevinj4891's Avatar
pm'd
read the PM.kinda things i already knew, some i didn't......
i kinda want it cause it will look good with my gray car, plus i wanted to try and go wingless, and this was a way i could do it without plugging holes (no one really has a slate metallic car to trade things off of)
Old Jul 30, 2010 | 10:05 PM
BLAZIN07SS's Avatar
I'm too JDM for you
there is the one "bumpstop" that you can adjust which is that little piece that touches the trunk mount to. and then you can loosen the actual bracket from the car(2 bolts holding the trunk hinge to the car), there is a lot of play in that and room for adjustability
Old Jul 30, 2010 | 11:25 PM
Bumpin Balt's Avatar
I haven't seen a CF trunk that fits properly yet. This is why I am painting a wingless steel lid with no holes starting tomorrow.
Old Jul 31, 2010 | 03:49 PM
Caligula's Avatar
My trunk seems to fit great. I dont know if it leaks though. I never drive the car in the rain.
I have the VIS.
dennis69
Oct 20, 2015 04:49 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Snail_SS
Sep 11, 2015 01:02 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
