Is it safe?
Old Feb 21, 2007 | 04:22 PM
1BADSS/SC's Avatar
Is it safe?
I was thinking about replacing all the vacuum hosing with red silicon hosing. I noticed all the hoses are REALLY thick ( thicker than the silicon ), and some of them are almost touching the engine. Would it be safe to replace all the hosing??
Old Feb 21, 2007 | 04:23 PM
D4u2s0t's Avatar
just curious as to why you would want to change them
Old Feb 21, 2007 | 04:28 PM
1BADSS/SC's Avatar
Typically silicon is much higher quality than factory hosing. Not to mention it looks sweet if you change out the black hoses for red, blue, green, or whatever color you can get. Its primarily used for engine dress up.
Old Feb 21, 2007 | 04:29 PM
stotte20's Avatar
i think c/a sells these
Old Feb 21, 2007 | 04:35 PM
1BADSS/SC's Avatar
probably. I just bought some from auto zone though..
Old Feb 21, 2007 | 04:41 PM
07cobaltss's Avatar
you will be fine, try to avoid moving any of them around tho, dont re run them into anywhere else. also watch out for high heat areas
Old Feb 21, 2007 | 04:43 PM
1BADSS/SC's Avatar
The large hoses that run near the engine, do you think it would be safe to change those or no... They run directly above the engine, kind of go around it.
Old Feb 21, 2007 | 04:46 PM
biohazard's Avatar
Get low
no order a kit online for the bigger ones.. also silicone flexs more than the factory ones, make sure it doesnt kink or itll blow up like a water balloon
Old Feb 21, 2007 | 07:40 PM
DTM2188's Avatar
Take some pictures when you finish replacing them, I am thinking about doing something similar and would like to see how it turns out. Best of luck!
Old Feb 21, 2007 | 07:48 PM
tio's Avatar
tio
Lots of kits available online, should be fine.
Old Feb 21, 2007 | 08:59 PM
1BADSS/SC's Avatar
So I bought the hosing from autozone, and decided instead of replacing the stock hoses Id just wrap the silicone around them. It looks pretty damn sweet, and can easily be removed for access to the stock hoses. Ill post some pics...
HERES A PIC OF WHAT IVE DONE SO FAR. I STILL GOT LOTS MORE TO DO.
Old Feb 21, 2007 | 09:23 PM
IonNinja's Avatar
good choice, less risk involved this way too.
Old Feb 21, 2007 | 09:28 PM
1BADSS/SC's Avatar
yea, i dont want any unnecessary air leaks...
Old Feb 22, 2007 | 07:18 AM
DTM2188's Avatar
I'm liking it man, get some more pics as you finish up if you don't mind.
Old Feb 22, 2007 | 08:03 AM
css9450's Avatar
I would suggest finding a more efficient and neater way to route the hoses instead - the stock hose arrangement on the Cobalt engine looks like a spaghetti bowl. Is that something you really want to call attention to by dressing it up with color?
Old Feb 22, 2007 | 10:55 AM
1BADSS/SC's Avatar
I would like to do that, but unfortunately I dont want to compromise the integrity of the stock hosing. It does look messy stock, but I dont care. All Im looking to do is make that mess look a little "cleaner" by doing a little engine dress up.
Old Feb 22, 2007 | 11:06 AM
Edubs's Avatar
It's okay to replace hosing, just make sure you know what you are doing. You have to know what the hose does before you replace it with another hose or even just re-route it. If you are aware of the functionality, you will realize that some hoses are routed for specific reasons, such as the fuel line that goes across the top of the valve cover. I re-routed that line, but I did so extremely cautious because a kink in that hose could be catastrophic for the engine. If you want to replace lines with different hosing, make sure the correct connections are used and that you use hosing that is better, or at the very least, as reliable as the stock hosing. I do plan on replacing and re-routing a lot of the hosing by the TB, but I'm planning this out thoroughly so that everything is safe and aesthetically pleasing...
My advice, look up the build book and identify each line, it’s purpose and then go out looking for an appropriate replacement. Don’t do this half-assed. If done right, this can make a great visual upgrade for your engine compartment.
Old Apr 15, 2007 | 09:44 AM
DTM2188's Avatar
Bump for any more pics? Sorry to bring back an old thread hahaha.
Old Apr 15, 2007 | 12:11 PM
cea2488's Avatar
Yeah, I wanna see some more pics too. It looked really good so far.
Old Apr 15, 2007 | 12:20 PM
shortyhend2004's Avatar
if you replace some of the hoses with that stuff they will collapse on them selves. Most of that stuff isnt made for that stuff.
Old Apr 15, 2007 | 12:23 PM
DTM2188's Avatar
I dont think he replaced them though, he wrapped them instead. Is that still a cause for concern?
Old Apr 15, 2007 | 12:38 PM
the way he did it was fine but to completely replace them you run the chance of blowing up or sucking shut!
Old Apr 15, 2007 | 01:38 PM
DTM2188's Avatar
Gotcha, thats what I thought, thanks! Now just need some more pics haha.
Rduncanss06
Sep 27, 2015 11:17 PM
TylerJHowell
Sep 21, 2015 06:47 PM
ATOMbomb
Sep 11, 2015 10:48 AM
Macgyver2484
Sep 2, 2015 05:44 PM
