Shaving Rear Emblems
Old Sep 5, 2005 | 07:49 AM
CopperLS's Avatar
can anyone tell how they're shaving the rear emblems? i heard you can just pull it aff, and us goo-away or sumthin to clean off any glue that may be left on ure trunk...
anyways for the people who have done it please share on how to do it
Old Sep 5, 2005 | 08:38 AM
05SDI's Avatar
Use fishing line. The multi strand line works better then the monofiliment. (spiderwire) Get under a corner and in a sawing motion cut the 3m type material beween the plastic emblem and the paint. Then use your fingers with a hairdryer or heat gun (careful) to remove the the remainder of the 3m type material. Clean up with WD40 or other products that will remove adhesive residue and wash your car. You will need to wax your car afterwards ot you'll still see where the emblem was for a while. 05SDI
Old Sep 7, 2005 | 12:17 PM
SilverSS/SC's Avatar
I just heated mine up with a heat gun . It made the adhesive pliable enuff to pull it off with my hands . Then used 3M adhesive remover to get the remaining adhesive off .
Old Sep 7, 2005 | 02:10 PM
blkcobalt's Avatar
Just Heat and clean
I removed mine with a blower dryer. Set the dryer on High heat, blow heat
directly on emblem (leave blowing for a few minutes). Slowly peel emblem
off. The remaning adhesive can be taken off with goo-gone, or WD-40.
Old Sep 7, 2005 | 02:40 PM
ShaunK's Avatar
Are you guys refering to the Chev emblem or the cobalt emblem?
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Delta coupe
Sep 30, 2015 08:11 AM
