Shift knob swap
Shift knob swap
Does anyone know if its possible to switch out the stock shift knob for a aftermarket one. If so how? And how do you get the bag to stay flush with the knob?
Idk about the Cobalt, but in the earlier model year Redlines, there was an issue with the shift knob shooting off of the shifter (it was spring loaded on). GM's solution was to glue it on with some super strong adhesive.
The 04 redline we had used to do that. the tsb wasnt for glue it was for the torx bit screw u now see in the top of the knob under the shift pattern. That thing used to hit the roof. Glad it never did it with the sunroof open. First time it did it I laughed my ass off!
I used a tap and die set. Threaded the shifter and then did a shift knob to fit. A little messy with the metal shavings, but simple enough to do. Gives more options of the shift knobs you can use too
ThoR294
Oct 4, 2015 08:44 PM
