Shift knob swap
Old Apr 1, 2013 | 08:11 AM
Supabalt's Avatar
Shift knob swap
Does anyone know if its possible to switch out the stock shift knob for a aftermarket one. If so how? And how do you get the bag to stay flush with the knob?
Old Apr 1, 2013 | 08:14 AM
09BlueBaltSS's Avatar
A vendor is working on an interchangeable knob for the stock shifter.
Old Apr 1, 2013 | 09:26 AM
dktgarlick's Avatar
^what vendor?
Old Apr 1, 2013 | 12:08 PM
BPS. I inquired about it weeks ago and they said it was in the works. Maybe show more interest and it will speed them up some.
Old Apr 1, 2013 | 12:16 PM
Old Apr 1, 2013 | 01:18 PM
gotboost?17's Avatar
Nothin Stock
Im down for one too,
Old Apr 1, 2013 | 09:46 PM
ionREDLINEracer's Avatar
Idk about the Cobalt, but in the earlier model year Redlines, there was an issue with the shift knob shooting off of the shifter (it was spring loaded on). GM's solution was to glue it on with some super strong adhesive.
Old Apr 1, 2013 | 10:12 PM
SSYellow06's Avatar
The 04 redline we had used to do that. the tsb wasnt for glue it was for the torx bit screw u now see in the top of the knob under the shift pattern. That thing used to hit the roof. Glad it never did it with the sunroof open. First time it did it I laughed my ass off!
Old Apr 3, 2013 | 06:55 PM
w-robertson's Avatar
I used a tap and die set. Threaded the shifter and then did a shift knob to fit. A little messy with the metal shavings, but simple enough to do. Gives more options of the shift knobs you can use too
Old Apr 3, 2013 | 07:03 PM
andrewcarr1993's Avatar
I've had mine off on the base and it's rather easy. Although there aren't any threads to hold it on but I'm considering a short shifter in the near future anyways.
Old Apr 3, 2013 | 07:28 PM
Nothin Stock
pics? how do u get it off anyway
Old Apr 4, 2013 | 09:08 AM
Pry off the 5spd pattern, remove screw then pull up as if you were Thor. The lsj I took off the other day was splined
Old Apr 4, 2013 | 09:26 AM
Nothin Stock
Okay sweet any pictures of your setup?
RaginChopsuey
Oct 27, 2015 01:27 PM
ThoR294
Oct 4, 2015 08:44 PM
footballplaya3k
Sep 30, 2015 09:39 PM
2009blackSS
Sep 30, 2015 05:57 PM
