Show your HID's
Whatever anzo's are, if they're not projectors they are not better. But go ahead and do what you please... as you see in this thread the majority of HID's are without projectors here.
No those are not projectors. Those are just stock lights. BUYHIDS.COM HID Lights HID Kits Xenon Headlights Kit HID Headlight Kits HID Conversion Light We sell Projectors modded for HIDs which are pre-installed or retrofits.
Here's the deal. HID bulbs are a lot brighter than your stock halogen bulbs. Something like 3x brighter. What projectors do is take advantage of said brightness and 'project' the light a lot further as well as radially. Don't get me wrong, HID's in reflector housings will be brighter than a halogen bulb in the same housing but by not using projectors you are negating the advantage of the brighter bulb, to an extent.
SKU: 121154
C.A.D. - Computer designed for innovative trend setting design
Changes the look of the vehicle in 30 minutes
New application for most makes and models
All D.O.T. compliant to FMVSS-108
OEM Style weather tight connections and wire harnessess
Simply plug and play
Illuminate your driving experience with the power of Anzo USA Headlights. These powerful beams are engineered using the state-of-the-art CAD technology that ensures impressive style and fit. Whether youre looking to update cracked, faded and yellowing headlights or just want to add style to your front-end, Anzo USA Headlights provide the infusion of light you need.
Bursting with quality, Anzo USA Headlights are extensively tested to withstand even the toughest weather conditions. Their simple, plug and play installation upgrades the look of your ride in less than 30 minutes on most vehicles. Enjoy the added safety and style of lighting up your path with Anzo USA headlights.
These projector headlights are available for most vehicles with the latest halo designs that utilize CCFL technology for a clear, high-efficiency beam. Plus, theyre DOT and FMVSS No. 108 compliant.
Finally had my car and good camera in the same place, and washed my car so I got some good pictures of my lights.
6k retrofit from buyhids.com. I must say, it does make quite the difference having the HIDs in projectors. Having been skeptical of HIDs period prior to this, I must say I'm now a believer. The buyhid kits are also very easy to install and they look to be of great quality. I would recommend them to anyone, and I intend on picking up a 3k fog kit in the spring.
ZZPs i believe are High/Low Kits which are HID low Halogen Highs just like out High/Low Kits. Our Bi-Xenons are "True" Bi-Xenons with a bulb that tilts for proper highbeam pattern where others the bulb goes in a out which barely changes the pattern of light. We always have deals, just have to PM us and ask
The zzp kits have a halogen bulb built into the light along with the hid bulb. When you switch to high beam, the bulb switches from running the hid bulb to running a halogen bulb as a high beam. With the buyhids bulb, the bulb physical moves, just like a stock halogen bulb does. This way, you have hid low beam, and high beam.
YouTube - 2010 Cobalt SS/TC with ZZPerformance 6000K HID Kit
Stock halogens don't move. The high beam filament is positioned differently in the bulb which creates a different pattern and consumers more power and is therefore brighter. That's why when u pull back on the headlight control u get both low and high on at the same time in their proper positions. Nothing moves
