Small drill hole fix this headlight?
Old Mar 13, 2011 | 02:59 PM
JayCress's Avatar
well I know theres been 100 of these threads but whats one more..
I have the great moisture in my headlight and I wanna get rid of it.
My question is will drilling a hole in the headlight fix it?
also:
what size drill bit? the smallest I can find?
Do I drill it in the bottom of the headlight?
and should I drill it in the left, middle, or right of it?
thanks a lot. Im only asking bc Im slightly confused as it seems to me that it'd cause more moisture to come into the headlight.
Onto the picture:
Thanks,
-Jay
Old Mar 13, 2011 | 03:01 PM
BlackARCA06's Avatar
Just get a heat gun or hair dryer and dry up all the moisture, then reseal them.
TommyP's Avatar
AWD > FWD
I would try drilling a small hole and see if it fixes it. Drill it in the bottom of the light. If that doesn't work, you could always just fill the hole back up with silicone.
Old Mar 13, 2011 | 03:03 PM
northvibe's Avatar
this.
Old Mar 13, 2011 | 03:07 PM
NCC-2000's Avatar
Why drill holes. Just one more thing to go wrong. Just remove the bulb and let the moisture out naturally. Blow dryer if you wanna dry the lens quickly, but let it sit for a bit anyway to let the moisture escape.
Old Mar 13, 2011 | 03:11 PM
TommyP's Avatar
AWD > FWD
If you don't want to drill a hole, put the headlight back in the oven at 200*, wait until all the moisture is gone, then while the headlights are good and warm, put some clamps (or something similar) and use it to SQUEEZE the headlights back together, and let it sit squeezed back together until they cool and the sealant hardens.
Old Mar 13, 2011 | 03:26 PM
JayCress's Avatar
well Id rather not bake them.. if nothing works Ill just deal with it.
but thanks for everybodys help. Also, I already let it dry naturally and it came back, not right away but still came back. Ill probably do that and drill it.
thanks again guys.
Old Mar 13, 2011 | 03:28 PM
northvibe's Avatar
take the bulb out, get a blow dryer. get the condensation out. and silicone the **** out of the lens. its easy, wont wreck anything and they wont leak anymore.
Old Mar 13, 2011 | 04:06 PM
Sweetsandman's Avatar
Drilling a hole will let the moisture out. It also lets moisture back in. I don't believe in that method. The best (and IMO only) way to 100% solve that is to take the headlight apart, dry it out, reseal it.
Old Mar 13, 2011 | 04:39 PM
mongorat427's Avatar
Wear gloves while doing this
Old Mar 13, 2011 | 05:15 PM
Garret's Avatar
hahaha I see you've run into similar problems hahaa
Old Mar 13, 2011 | 05:30 PM
BlackLsCoupe's Avatar
whys that?? lol
i got retros from buyhids and i cant seem to stop the water resealed and sealed all the openings in the back.
Old Mar 13, 2011 | 05:32 PM
Garret's Avatar
i burnt my finger tips, I assume mongo did too
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
dieGone
Oct 1, 2015 06:27 PM
Slick_Nick
Sep 28, 2015 09:15 PM
Sep 27, 2015 08:53 PM
