SS cluster
Old Aug 13, 2010 | 06:03 PM
boostedsport's Avatar
SS cluster
before with blackcat leds
now
and it only reads coolant temp which was the last thing i was looking at on the other cluster also makes the worst turn signal noise known to man. Looks nice though
Last edited by boostedsport; Aug 13, 2010 at 06:03 PM. Reason: Automerged Doublepost
Old Aug 13, 2010 | 06:13 PM
raymondb's Avatar
Because its not from the same year.....
Old Aug 13, 2010 | 06:19 PM
i dont think so because on the install thread it said no matter what year they partially work this really doesn't work at all. Only shows coolant temp i have a 2008 2.4 Sport
Old Aug 13, 2010 | 06:20 PM
bbrewbaker's Avatar
What year is the cluster from?
Old Aug 13, 2010 | 06:27 PM
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories
05-06 will partly work with 07+, you will only see the mileage and temperature, you lose all other DIC features
07 will work on 08+, everything will work except the TPMS light (TMPS still works though)
08-10 work with 08-10, everything will work
i have nothing expect coolant temp wtf and the turn signal noise is from hell loving the TC disabled light though!
Old Aug 13, 2010 | 06:32 PM
hook's Avatar
i was told by many members and the dealer that not all years are the same i put ss gauges in kph in mine and they work great. must be wrong year gauges man
Old Aug 13, 2010 | 06:36 PM
the whole point of getting the SS cluster wasnt for the look when i got those blackcat custom LEDS the guy who took my needle off messed up on the MPH and i ended up getting a ticket. Once you remove that needle from the factory its never the same. Atleast now i'm looking good and i know my true speed and RPMs it was off 300-400 before. I'll have my PLX odbII installed soon enough so no biggie loosing the DIC but hey i can read my coolant temp in the mean time.
Old Aug 13, 2010 | 06:37 PM
bbrewbaker's Avatar
It might be from a 06.
If so that would cause the issue.
It's listed as COBALT 06 US, 2.0l on the above link.
Old Aug 13, 2010 | 06:43 PM
NWAE Cobalt's Avatar
it is the year, we tried this with a buddies as well...i have swapped plenty over...and only the right years will work...if you dont do that you will get the annoying double ding and not be able to change the dtc thingy
Old Aug 13, 2010 | 06:46 PM
all the other 2008 SS clusters i find on ebay only read up to 120 thats 20 less then what i had before????
whats the point in having a ss cluster if it doesn't read to 160 and work for my car like it should?
yepp double ding u nailed it
look at this one for 430!!!
http://www.everdrive.com/partdetails...paign=shopping
Last edited by boostedsport; Aug 13, 2010 at 06:49 PM. Reason: Automerged Doublepost
Old Aug 13, 2010 | 06:47 PM
CordiaDOHC's Avatar
my 09 LNF cluster works perfectly in my 08 2.4 sport. Everything works like it should. Should of looked around for a closer match year wise on the cluster.
Old Aug 13, 2010 | 06:52 PM
the only 09 i'm seeing only read to 140 but there SS style thats the LNF one?
Old Aug 13, 2010 | 06:55 PM
CordiaDOHC's Avatar
all boosted SS models came with 160mph gauges if they are american cars.
So all LSJ and LNF cars have the black faced 160mph cluster. Mines out of a 2009 SS LNF car.
Old Aug 13, 2010 | 07:33 PM
Icydub's Avatar
To everyone saying you need the same year: NO YOU DONT.
But yes, getting the same year guarantees everything will work, but it is possible to have everything work by using a different year.
Interchange: COBALT 06 US, 2.0L
You got an 06 cluster for your 08 car. The guide tells you it will partly work, and partly work is exactly what happened. If you wanted everything else to work, you should have gotten an 08+ cluster for your 2008 model. If you can live without the TPMS light, then a 07 cluster would work too.
Old Aug 13, 2010 | 10:49 PM
nah homie it dont work at all i would say reading coolant temp 24/7 is not partly working and i'm not seeing too many 09 TC clusters
Old Aug 13, 2010 | 10:57 PM
nikemax21's Avatar
Im pretty sure that link has a honda cluster..... unless your just referring to the price then fail on me.....
Old Aug 14, 2010 | 01:32 AM
Icydub's Avatar
Well it didn't not work, and it didn't fully work.. so partly work is what you would describe it
Old Aug 14, 2010 | 02:15 AM
CordiaDOHC's Avatar
08-10 clusters will work for you. I got mine from one of the wrecked ss/tc cars zzp had.
ineedacobaltss
Nov 7, 2015 02:25 PM
satisfied
Oct 19, 2015 12:35 AM
jmelton327
Sep 26, 2015 10:04 PM
Aug 29, 2015 03:11 PM
