SS wing installation
look up the 'guinea pigs needed' for wing plugs thread there was a whole discussion on it. all wings seem to have slightly different holes but i dont think its a problem, as the base is big enough to cover all of them up
It's kindof an unknown thing depending on your car as no one can determine what cars have what hole types currently, I would also suggest reading the spoiler plug discussion
AFAIK, as long as you are going coupe to coupe (or sedan to sedan) the wings should be a bolt on swap - not taking into consideration getting all the double sided tape to let go without scratching the #$&^ out of your trunk lid
Bolts plus some super duty industrial strength double sided tape is what the factory used.
Once you get the bolts out you can use a bit of heat (hair dryer maybe?) to soften the adhesive and a piece of fine fishing line to cut through it. Once you get it off, goo gone and elbow grease should take care of the remaining adhesive.
so from what I've seen....
LS/(LT maybe)have just the 4 holes like pictured above
SS/SC's & SS/TC's that came from the factory with the highrise have the 2 holes an 2 holes w/ half moon holes around em
an the SS/TC's that had the lowrise from factory have the 2 holes w/ half moon holes and rectangles...
that bout sums up what we've learned so far
bam
Delta coupe
Sep 30, 2015 08:11 AM
