SS wing installation
Old Sep 15, 2011 | 02:31 PM
10Cobalt_SS's Avatar
Is the SS wing opposed to the regular wing a direct fit? same holes may be used?
Old Sep 15, 2011 | 02:33 PM
look up the 'guinea pigs needed' for wing plugs thread there was a whole discussion on it. all wings seem to have slightly different holes but i dont think its a problem, as the base is big enough to cover all of them up
Old Sep 15, 2011 | 03:06 PM
JshLnsctt's Avatar
It's kindof an unknown thing depending on your car as no one can determine what cars have what hole types currently, I would also suggest reading the spoiler plug discussion
Old Sep 15, 2011 | 03:45 PM
MitchSS's Avatar
Should be a direct fit. Mine came with the low-rise spoiler i swapped to the high-rise in minutes. Exact same hole spacing
Old Sep 15, 2011 | 06:36 PM
DaBuzzard's Avatar
AFAIK, as long as you are going coupe to coupe (or sedan to sedan) the wings should be a bolt on swap - not taking into consideration getting all the double sided tape to let go without scratching the #$&^ out of your trunk lid
Old Sep 15, 2011 | 09:36 PM
ok good...is it just bolts or adhesive also? anything work good to take off the adhesive?
Old Sep 16, 2011 | 12:11 PM
DaBuzzard's Avatar
Bolts plus some super duty industrial strength double sided tape is what the factory used.
Once you get the bolts out you can use a bit of heat (hair dryer maybe?) to soften the adhesive and a piece of fine fishing line to cut through it. Once you get it off, goo gone and elbow grease should take care of the remaining adhesive.
Old Sep 16, 2011 | 12:28 PM
MastaShaKe_88's Avatar
Originally Posted by MastaShaKe_88
so from what I've seen....
LS/(LT maybe)have just the 4 holes like pictured above
SS/SC's & SS/TC's that came from the factory with the highrise have the 2 holes an 2 holes w/ half moon holes around em
an the SS/TC's that had the lowrise from factory have the 2 holes w/ half moon holes and rectangles...
that bout sums up what we've learned so far
bam
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
