suede headliner/ sunroof slider
Old Mar 21, 2011 | 11:07 PM
myfakeevo's Avatar
Originally Posted by MastaShaKe_88
huh.. i nerve really have to clean my roof... but I guess I can figure out how to take it off an put it back on with out ripen stuff 2 bad but as far as vinyl paint tho, you jus spray it on?
5 cans of vinyl paint that you can get at pep boys at 8 dollars a can. you have to take the whole sunroof assembly out which wasnt the fun o meter
Old Mar 21, 2011 | 11:43 PM
cobaltsssc760's Avatar
the sunroof removal is cake takes 5 min i guess i will try and cover it with the suede. i dont like how shiney it looks after paint i was gonna paint the pillars the same color and i dont waht them shiney like that.
Old Mar 21, 2011 | 11:52 PM
Urban Rogue's Avatar
I just took the sunroof sliding piece out. didnt have to remove the sunroof assembly at all.
Old Mar 22, 2011 | 12:10 AM
whyyoumadson?'s Avatar
dont use rattle can....check it out. heres a base model tan interior to black...no rattle can except the fabric parts.
Old Mar 22, 2011 | 12:15 AM
MastaShaKe_88's Avatar
well watd you use on the plastic?? an like dude said, I don't like the shiney look either ... I like how whyyoumadson? did his dash, came out perfect an stockish lookin... I'm shootin for somethin like that..
Old Mar 22, 2011 | 12:16 AM
special sealer that adheres to plastic. basecoat with hardner and flex
Old Mar 22, 2011 | 12:22 AM
this is sounding more an more like somethin I shouldn't' do myself How much would somethin like this run to get done professionally? like roof, sunroof piece, dash, an doors? That'd be the only way I could get it done... I don't like the whole mismatch look
Old Mar 22, 2011 | 12:25 AM
thats the oem color..... its slightly off but i doubt you would really notice it in all honesty. repainting everything is a lot.....
just do the upper half of the car an d call it a day...the way you talk if your going to do the doors quarter trim and all that non sense you might aswell do the dash and crap.....which doing the glovebox, cubby hole areas are a nightmare and wont last.
Old Mar 22, 2011 | 12:36 AM
gdubs's Avatar
Try painting the weather stripping with plasti-dip
Old Mar 22, 2011 | 12:54 AM
^^ Ima jus leave well enough alone... well till I follow thru with this winnin the lottery plan that I've been plottin
Old Mar 22, 2011 | 01:03 AM
  #36
^^^^ haha
im not just gonna rattle can them im gonna take the time to primer, color, clear and fine wetsand all the way to 2000 and then hit it with some rubbing compound. should come out real nice from rattle can.
Old Mar 22, 2011 | 01:41 AM
  #37
myfakeevo's Avatar
the flash on my camera just gives off more of a shine that what is really seen. i used flat black
Old Mar 25, 2011 | 09:54 PM
  #38
YellowSS06's Avatar
So, I dropped the back half of the assembly, and removed the little bar that goes across. I still cannot get that damn shade to slide out. Anywhere else something may be attached, that I'm not seeing?
Old Mar 25, 2011 | 10:04 PM
  #39
myfakeevo's Avatar
i said it was just easier to take the sunroof out
Old Mar 25, 2011 | 10:53 PM
  #40
YellowSS06's Avatar
Well, lets just say I cant move the sunroof to get the last screws out and remove the glass. It would make taking the whole thing out a lot easier. And by myself, the weight of all of it combined with bad leverage from sitting under it means I can't take it all out at once. I just dont want it falling on me. lol
Old Mar 26, 2011 | 08:38 AM
  #41
theres 2 torx screws on the top to remove a beam in the rear. after thats removed you might see these 2 little things that are sort of a stopper. they are real big and you can work the sunroof piece past it. you can see with a light just toy with the sunroof piece and give it a good tug and it should sneak past them.
Old Mar 26, 2011 | 03:35 PM
  #42
YellowSS06's Avatar
Okay... I put the bar back in last night so I wouldn't lose anything. I'll take it back out and give it a shot since I have better light. I didn't see the other stoppers before. Thanks!
Old Apr 4, 2011 | 05:22 AM
  #43
YellowSS06's Avatar
Anyone ever figure out what kind of weather stripping to get for this?
Old Apr 4, 2011 | 06:01 AM
  #44
iboost's Avatar
sub'd
Old Apr 4, 2011 | 09:19 PM
  #45
i had it painted with special paint at the local painter. turned out good just have to go back and have trim pieces painted and front pillars and get visors covered,.
Jan 12, 2016 12:01 AM
chefhhr
Oct 26, 2015 10:36 PM
dennis69
Oct 20, 2015 04:49 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
