Switchback LED turn signal as running lights with load resistor?
Old 09-25-2010, 04:13 AM
Tyler1990's Avatar
I tried looking around, couldnt find anything. Needa know how to wire this up!
Thanks!
Old 09-25-2010, 08:23 AM
AWD > FWD
TommyP's Avatar
You put the bulb in. tap one end of resistor into blue posative for turn signal. Tap negative into ground. If you want to put resistors on the white side as well to protect them. Tap one end of resistor onto the brown parking light wire, and the other end to a ground. The end.
Old 09-25-2010, 08:26 AM
NCC-2000's Avatar
Resistors for turn signals don't "protect" anything, they just mimic the presence of a light bulb to stop the car from thinking a bulb is burnt out. Putting a resistor on the parking light wire will just cause the resistor to get abnormally hot and possibly start melting things or catch fire. Not a smart idea.
Old 09-25-2010, 09:35 AM
Koenreich's Avatar
Solution: no resistor on your switchbacks and get K2 smoked LED tail lights and don't get resistors.
Old 09-25-2010, 10:16 AM
DFZ24's Avatar
mines get hot as hell that means i connected wrong??? but the fast/quick blinking when using the turn signal stop....
Old 09-25-2010, 10:53 AM
NCC-2000's Avatar
No that's connected right, but that's why I said connecting a resistor to the parking lights is a bad idea. Yours gets hot when the signal is on, just imagine how hot it would get if the resistor was "on" constantly. Just trying to keep things from burning.
Old 09-25-2010, 10:57 PM
Tyler1990's Avatar
..? So how any way to make my led turn signals turn on when my lights are on? i have resistors. thanks for any help
Old 09-25-2010, 11:59 PM
heathkidder's Avatar
ok so are u sayin noone should get different bulbs or leds cause there 4 you must get resistors to make it stop but ur sayin gettin them is a bad idea so there for my as well not get leds or diff. bulbs period right lol
Old 09-26-2010, 12:44 AM
AWD > FWD
TommyP's Avatar
No I think he's just saying put the resistors only on the turn signal part.
Old 09-26-2010, 12:45 AM
well duh where else would u put it lol or better ? is why put it newhere else
Old 09-26-2010, 11:03 AM
NCC-2000's Avatar
Resistors connected to the parking lights is what the bad idea is, which is what was mentioned a few posts back. Using the resistors on the turn signals, the way they were meant to be used and what they were designed for, is perfectly fine. They are only meant to stop the hyper flashing of the turn signal anyway.
Old 09-26-2010, 09:12 PM
so u tap into the blue and black wire correct nuthin else cause i noticed theres red red and black also on the same bulb
Old 10-27-2010, 06:30 PM
RoadconeTuning's Avatar
what about if your switchbacks work fine as a turn signal but the white running lamp does come on... i just tried a set of red led taillight bulbs from vleds as well in my moms g5 and they worked as a brake light but they didnt work as a running lamp...
its as if the bcm sees a "Short" and opens the circuit for that bulb and keeping the running lamps from working
Old 11-02-2010, 05:48 PM
HKnoma's Avatar
Need help. Installed K2 LED tails and now my blinkers are doing the quick flash. How do I stop this?
Old 11-02-2010, 05:52 PM
AWD > FWD
TommyP's Avatar
resistors, the same ones you would use for led turn signals. link is in the headlight and tail light sticky.
Old 11-03-2010, 06:35 PM
HKnoma's Avatar
Thanks!, have some on order w/ heat shields... Until then JDM turn signals baby yeaa
Old 11-04-2010, 12:37 AM
Cobalt08LS's Avatar
tap the black and the blue wire for driver side and black and the yellow wire for passanger.
for some reason theres a yellow wire on passanger side rather than blue.
brandon04
10-21-2015 07:04 AM
roth
09-26-2015 12:16 PM
Quick Reply: Switchback LED turn signal as running lights with load resistor?
