temporary wingless?
Old May 25, 2011 | 05:00 PM
der_meister_08's Avatar
temporary wingless?
ive been doing some searching and so far no luck. im trying to find some sort of a plug that i can block off the holes in the trunk. i want to go wingless but i know as much as i change my mind ill probly want to go back at some point so i figured it would be a good solution to find some plugs and have them color matched.
any input is appreciated guys, thanks
Old May 25, 2011 | 05:14 PM
tunameltman's Avatar
Just measure the size of the holes and go up to Ace hardware or whatever local hardware store you have and pick up some plastic caps in the same size. I'm about to do this myself because I hate the lowrise wing
Old May 25, 2011 | 10:15 PM
Hammbones's Avatar
Advance Auto had some 2 Inch panel push rivets. I wrapped mine in White Vinyl, trimmed a little edge piece at the base of the screw stud so it would fit into the holes from the wing and then used hot glue on the inside to seal it off from water. Cost me about $6.
Old May 25, 2011 | 10:36 PM
AndrewSS/TC's Avatar
This. /thread
Old May 26, 2011 | 04:41 PM
sweet thanks alot guys
Old May 26, 2011 | 04:44 PM
samsumthing's Avatar
yeah, plugs work, but dont look the best. perfect example:
Old May 27, 2011 | 06:10 AM
do you have a pic of the holes before you plugged them by any chance?
Old May 27, 2011 | 07:54 AM
Sweetsandman's Avatar
Plugs look like poo. If you don't mind the poo look...then go for it.
Old May 27, 2011 | 08:23 AM
jmesl8er's Avatar
Looks bad because its not colormatches. I colormatched the plugs for the license plate holder, it looks good
Old May 27, 2011 | 08:41 AM
Those are also substantially smaller plugs.
Old May 27, 2011 | 11:11 AM
unfortunately, no. just know the holes in the back are ridiculously big for some reason. the holes are actually 3 different sizes, which is pretty annoying. it you look where the spoiler is bolted in the trunk, you can get a good idea of the size, and how they are shaped.
Old May 27, 2011 | 11:16 AM
dayhoff35's Avatar
i just used electrical tape, i had a black car though and you couldnt tell from more then like 5 feet away so if your cars black that would work
Old May 27, 2011 | 01:41 PM
jmesl8er's Avatar
colormatched still looks better, doesnt matter what size the plugs are
ROADKONE
Sep 9, 2015 02:32 PM
themacguy
Aug 26, 2015 07:18 PM
2K5SS/SC?
Jan 28, 2007 11:47 PM
SymbioteLT
Jun 13, 2006 11:46 AM
