For those with swirls
Old May 15, 2006 | 04:08 PM
Cobalt443's Avatar
I have owned numerous black cars and no matter what you do it's pretty much inevitable that you will develop swirls.
Anyhow, I've finally found something that's extremely easy to use and get's the best results out of everything I've ever used.
I used to use Mother's 2 stage, but I've noticed it takes out minimal swirls.
So I've started using Meguire's swirl Remover 2.0 I highly recommend this product. It is safe for all clear coats and extremely easy to wipe off (Don't use on a hot surface or in direct sunlight) You can apply by hand or orbital buffer.
It ran my about $8.00 at the swap meet. However, I would recommend using Mother's Stage 1 before applying to remove any/all oxidation or crap that may be on the car. (It's a cleaner wax) And for best results, after applying the swirl remover, use Mother's Stage 3 which is a pure carnuba wax.
Good luck everyone and thought I would just pass on this info to anyone who was also plagued with the swirls
Old May 15, 2006 | 04:32 PM
RedBaseBolt's Avatar
Thanks for the info, I have a red car and I too am plauged by many swirls.
I'm gonna try that out.
Old May 15, 2006 | 04:48 PM
Cobalt443's Avatar
You won't be dissapointed, especially with red since their not as easy to see and I'm very picky when it comes to black.
Old May 15, 2006 | 05:07 PM
juststickit124's Avatar
They come in stages? any horsepower gain? jk, sounds good i'll try it on my black 99 Dakota
Old May 15, 2006 | 05:18 PM
WJT DEMON's Avatar
Another swell product is 3M hand glaze.
Old May 15, 2006 | 05:46 PM
Doc's Avatar
Doc
3M makes awesome products. I had my black truck color sanded and that took all the swirls out. Basically it was reshot and then wet sanded to take out the imperfections. I don't remember what it cost, but it looked like liquid and was well worth it.
Old May 15, 2006 | 05:56 PM
snowbred's Avatar
i use meguiars stage 1 and 2 should i apply the swirl remover after stage 1? stage 2 is the polish.
Old May 16, 2006 | 12:48 PM
Cobalt443's Avatar
since stage one is most likely the cleaner phase, use the swirl remover after stage 1 and you'll be good. Then, just apply your normal stage 2 after the swirl remover. (check to make sure your stage 2 is a carnuba wax and not also a mild swirl remover)
Old May 16, 2006 | 10:39 PM
drocher's Avatar
all ive used is meguiars scratch X..mothers would work better for swirls?
Old May 17, 2006 | 12:06 PM
Cobalt443's Avatar
no mother's stage 2 is alright for swirls but only very minor ones...I now recommend using Meguire's swirl remover 2.0
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
Infamous
Show & Shine
Aug 1, 2008 02:23 PM
Wolf117
Show & Shine
22
Jun 20, 2008 12:38 AM
rrutter81
Show & Shine
60
May 10, 2008 01:22 PM
TheDaves413
Show & Shine
12
Dec 4, 2007 12:45 PM
