For those of you with LED reverse/tail/sidemarker lights...
not to threadjack but im still having a problem. i used 6 ohm resistors like a few ppl have said to use and my lights still act up. they'll be blinking fine then for a few seconds go hyper blink, then back to normal for a few seconds, then back to hyper. any ideas?
so today i redid my wiring. i cut out those quick splice things and used crimp disconnects. the passenger side seems to be working fine but the drivers side is still being stupid. i switched the wires around and also tried a different resistor and it still does it. it blinks fine for a minute or so but once it warms up i guess it starts to blink fast. someone help!
The hyper blinking doesn't stop on either tail light until one resistor is wired into the passenger side and one resistor is wired into the driver side.
The v-led site says it may take a minute for resistor to work but they worked instantly for me.
ok so ive been reading that when you turn your stock brake/turn signal light to led when you put you turn signal on its wicked fast does it still look like its flashing or does it need a resistior to slow down the blinking and if you need the resistors do you have to put them on the side markers as well?
this might be a dumb question but is this impala third brake light is it actually out of a impala or is just the name of the style it is
im lookin for a good looking led light or different style third break light for my cobalt and been trying to find clear oem side marker lights too
