tinting tail light problem
Old Oct 28, 2008 | 11:54 PM
RobertSS's Avatar
i tinted my side markers with a tint spray and applied the duplicolor clear coat and it just doesnt look right.
i sanded the lights with wet sand 1500 grit before each clear coat and the lights dont looks glossy or shiny at all :S they after each clear coat application the light looks grainy, and sanding that done makes it smooth but at the same time it makes it looks very dull, almost as if i painted it with a sharpie :S
what am i doing wrong?
Old Oct 28, 2008 | 11:57 PM
FZWCobalt_09's Avatar
Get a small buffer and use it on the lights it should shine them right up!
Old Oct 29, 2008 | 12:01 AM
RobertSS's Avatar
do you recomend a certain buffer? or which one did you use? lol
Old Oct 29, 2008 | 12:09 AM
Large W's Avatar
Use polishing compound.
Don't use rubing.
Old Oct 29, 2008 | 12:10 AM
dont matter and i used 3m polishing compound
Old Oct 29, 2008 | 12:14 AM
RobertSS's Avatar
alrightt thanks guys! ill be sure to get that tomorrow
Old Oct 30, 2008 | 08:27 AM
hailcesar75's Avatar
also check the days humidity. Make sure it's not above 55f when you do the clear. I did it once and my clearcoat came out a hazy dull look
Old Oct 30, 2008 | 02:06 PM
AzCobaltMan's Avatar
lol if you couldnt apply clear it its over 55 F then use people in arizona cant do it? i know what you mean just making a stupid coment.
Old Oct 30, 2008 | 02:11 PM
Nymostwanted187's Avatar
Polishing compound should do the trick
before
After
Old Oct 30, 2008 | 02:49 PM
oops I meant 55% humidity. Does sedan tails came out sweeeeeet!!!!
Old Oct 30, 2008 | 04:54 PM
Thanks!
Old Oct 30, 2008 | 05:09 PM
Hey nymostwanted. You got lowering springs on your Balt? It looks like it does on your sig
Old Oct 30, 2008 | 06:17 PM
Yea its on sportlines man.
Old Oct 30, 2008 | 06:51 PM
hows the ride is rough or is it the same. I've been contemplating on getting em for about 2 months now lol. but wasnt sure
Old Oct 30, 2008 | 06:54 PM
It's a bit more harsh, not a lot, but just a bit. but personally i think its totally worth it because it makes the car look a lot different lol
Old Oct 30, 2008 | 07:01 PM
any reason that you didnt go with the pro kit. sorry with all the questions, is that ive been getting mixed review. how much is the drop? i dont know if theres a diff drop with the ss that i have
Old Oct 30, 2008 | 07:07 PM
I looked at pics of the pro kit and it barely drops it lol They both might perform the same but i decided to go with the lower drop. On the 2.2's it drops it 2"front and 2.5" back. I think its the same on the 2.4's. Not sure though lol
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
