Trim removal
Old Nov 13, 2010 | 04:58 PM
DavidLaMattina's Avatar
Trim removal
How do i remove the window switch/handle surround thing? I started to pop it off but the side closest to the door panel doesn't want to come off and I don't want to break it.
Also, how do I remove the two pieces of plastic on the steering wheel where the cruise control buttons are?
Old Nov 13, 2010 | 05:12 PM
padlock's Avatar
for the window handle thinger you want to look where you grab. in that area there is a black plastic cover that is sort of a pain to get out (you need to push in the tab and pull up) my best advice is to get a small flathead screwdriver and work with it. once you take the cover off there are two screws holding it in; take out the screws and it comes out simple
as for the steering wheel pieces there is a how-to.. Ill track it down for you because telling you is rather hard without pics
Old Nov 13, 2010 | 05:13 PM
Thanks man, I'd appreciate it!
Old Nov 13, 2010 | 05:16 PM
padlock's Avatar
here you are with the steering wheel bezel removal.. its pretty simple
https://www.cobaltss.net/forums/how-...g-wheel-84011/
just outta curiousity, you painting your pieces or whats the story??
Old Nov 13, 2010 | 05:19 PM
Thanks! and yeah, I just got my new head unit/sub/amp installed and while I had the dash pieces off I figured I might as well paint them, so I'm painting them a Satin Black - nothing flashy, just trying to make them blend in a little more with my black interior. and now I'm going to paint the steering wheel pieces and the door handle things. I'll post pictures of everything once I get it all put back together.
Old Nov 13, 2010 | 05:23 PM
padlock's Avatar
yea thats sounds like it should be nice! i always hate it when ppl leave out painting the bezels cuz then the project looks incomplete..
make sure you use a paint for plastic.. just an fyi cuz i didnt the first time then had to do it over a couple months later
Old Nov 13, 2010 | 05:24 PM
Yeah, I'm using Krylon Fusion Plastic spray paint.
Old Nov 13, 2010 | 05:25 PM
padlock's Avatar
alrighty just checkin! thats the same stuff i used! works great
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
How to Guide
57
Oct 15, 2015 11:56 AM
Delta coupe
Sep 30, 2015 08:11 AM
