trunk swap ?
Old Dec 3, 2007 | 11:53 PM
stonny9's Avatar
trunk swap ?
I just found someone that want's to trade trunks but I have a few questions first.
How long should it take to switch both trunks?
Do u have to align them or just sraight bolt them on and be done?
Is the lock cylinder hard to change?
In short the steps are unhook wiring, remove lock cylinder, unbolt trunk, and then reverse these steps.
Will try to take pics if swap happens.
Old Dec 3, 2007 | 11:54 PM
anthonyS88's Avatar
what do you have the high rise trading for the low rise?
Old Dec 4, 2007 | 12:07 AM
stonny9's Avatar
My high rise trading for a wingless. Both are victory red. And he didnt know about .net
Old Dec 4, 2007 | 12:08 AM
anthonyS88's Avatar
sweet
Old Dec 4, 2007 | 05:57 AM
Black07LS's Avatar
Did this Sunday. Remove carpet, unplug reverce lights and third brake light, pop out clips that holt wire harness, 3 bolts that hold latch, disconect wires from latch, clip hold lock cylinder push it to the right with your thumb, pull wire harness from trunk, 2 nuts that hold trunk to hinge, Put 'em back together, align trunks (not hard). It took us about 1-1.5hr. Tools needed ratchet, 10mm socket, 10mm wrench, small flathead screwdriver, 11mm socket if you need to remove reverce lights and 3rd brake light.
ThoR294
Oct 4, 2015 08:44 PM
ThoR294
Sep 28, 2015 05:31 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
