Under Hood Blanket
Old Aug 13, 2006 | 08:04 PM
PenguinPIE's Avatar
dont have to get so hostile. i know the blanket is there to resist fire (read my earlier post), but im not sure about the plastic retainers which are designed to melt and drop when theres a fire?!
Old Aug 13, 2006 | 08:38 PM
trashline's Avatar
It makes a world of difference on an automobile fire under the hood. The insulation does drop down smothering the fire. which I can bet most fires start on the top end of the motor then spreading into the cabin thru the "firewall". All the plastics in todays cars make it even worse. Il opt to leave it on. If chevy thought that the engine temp was to high they would have adjusted the tstat fan controls or something along those lines.
I also believe the design of most cars with grilles allow the air to run over top of the motor and down under the cabin.
Old Aug 13, 2006 | 09:00 PM
zomghax's Avatar
Aftermarket hoods do not come with them. I'm going to roll the dice on this one.
Old Aug 14, 2006 | 12:32 PM
trashline's Avatar
Ive never bought an aftermarket hood. Arnt most fiberglass? Ive never seen an aftermakret hood for sale for my 66 that was steel unless someone molded a scoop onto a stock hood.
If most are fiberglass then they are fire retardent allready since thats what house insulation was made out of as well.
Old Aug 14, 2006 | 12:36 PM
D4u2s0t's Avatar
Originally Posted by xspyder85x
i think the world should go to junior bacon cheesburgers as a world wide currency
if it was a mcchicken with cheese i would be all about it
Old Aug 14, 2006 | 12:44 PM
xspyder85x's Avatar
you know you would like to have a wallet full of cheeseburgers
Old Aug 14, 2006 | 11:36 PM
redlineblueline's Avatar
Guys the hoods are metal, the engine is metal, removing the engine covers reduces the fire threat since modern car plastics burn with a very high heat load, over say an equal ammount of paper. Therefore platics burn hotter. However, if there were a fire its going to be a class B fire, flamable liquids, since metal is not going to burn, the gas is. If an electrical fire breaks out the fuel for that fire comes from the inslation on the wires and the conduit. Fires that break through the firewall do so at the points where wiring and hoses run through it. That thin "blanket" is going to get saturated though with gas and go up in flames itself. If you guys are so worried about fires buy an extinguisher or one of the supression systems.
Old Sep 8, 2006 | 12:25 PM
NLCobaltSS's Avatar
Does anyone have pics of this SS blanket installed?
Old Sep 8, 2006 | 12:31 PM
joeworkstoohard's Avatar
as stated, it is a safety feature and it does work. I also think it makes the engine compartment look more modern, but that's a personal thing. it keeps down noise and prevents the hood from getting as hot. moreover... removing it is pretty rice.
Old Sep 8, 2006 | 12:47 PM
johnkb8's Avatar
not installed but u get the idea....?
Old Sep 8, 2006 | 01:22 PM
  #36
R33P3R007's Avatar
360 L337 User
bad idea. you sir, have never tried to get 18 junior bacon cheeseburgers in your wallet after purchasing 2 with a 20.
  #37
I took it off the other night to see if there was any effect. The hood has no different heat transfer and the engine doesnt run any cooler.
Old Sep 8, 2006 | 01:45 PM
  #38
Jackalope's Avatar
Of corse the engine won't run any cooler. The hood doesn't act like a heat sink for the engine! Good Grief! Its to help with the sound deading of the engine. As for whole fire thing......its sounds reasonable and that stuff don't burn too easy so I'd say it has 2 purposes. Sound deading and this fire surpression theroy of you guys.
I've already ordered mine so when it comes in I'll post pcs.
Old Sep 8, 2006 | 02:48 PM
  #39
victory_red_SS's Avatar
LSX RWD S/C conversion
I have one of these on order and will post pics when it gets here.
Old Sep 12, 2006 | 03:19 PM
  #40
05BlackCobaltSS's Avatar
I've thought about getting one, but that's a pretty big chunk of change for something I'll rarely look at. I might get it one day for shows.
Old Sep 12, 2006 | 03:35 PM
  #41
BLKSS's Avatar
My buddies turbo on his spec V warped his carbon hood because of heat. I could imagine happening to us.
Old Sep 12, 2006 | 04:52 PM
  #42
Jackalope's Avatar
Woo Hoo! Its here! Looks damn good in person! I'll post pics as soon as I can. Install looks straight forward and easy enough.
Stand by for pics.
Old Sep 12, 2006 | 05:00 PM
  #43
kissmySS's Avatar
I install those everyday at work and it is EASY any problems?...step away from the car and go seek help...!
Old Sep 12, 2006 | 05:07 PM
  #44
Serpico's Avatar
Originally Posted by zomghax
Dude I ripped my underhood blanket out already, I'm not going to pay 125 junior bacon cheeseburgers for a new one
ROFL
Old Sep 12, 2006 | 05:53 PM
  #45
Old Sep 12, 2006 | 06:19 PM
  #46
FRIARPOP's Avatar
gmaccessorieshttp://www.gmgoodwrench.com/accessor...74641155513603
A link to gm accessories, they have 2 for sale if you dont want a ss on it. You can also take the part number and get it from gm parts direct for cheaper.
Old Sep 13, 2006 | 08:43 AM
  #47
Jackalope's Avatar
Took all of of 2 minutes to install, would have been only 1 but I dropped a clip and had to move the car. Looks great IMO and seeing how it only cost me 80 jr bacon cheese burgers I though it wasn't that hateful.
Old Dec 19, 2006 | 04:05 AM
  #48
opiumpot's Avatar
KK Sorry about the NEWB question since i've never had an underhood blanket in any of my previous cars but to remove it do I just pull on the clips or do i need a tool? Sorry but don't want to break the clips if the're not supposed to be pulled out by force.
GaryGibblez
Jan 14, 2020 10:35 AM
patooyee
Oct 15, 2015 05:11 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
Dipped_Cobalt
Sep 22, 2015 02:18 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
