V-LEDs V3 Triton Switchbacks pre-ordered!
V3 TRITON 6K WHITE AMBER TYPE 2 SWITCHBACK MULTI-APPLICATION HIGH POWER LED LIGHT SYSTEM 7443 1157 3157 | 1 PAIR B/O
Just pre-ordered some of these switchbacks to replace the 92 LED type 2 switchbacks I have in my front turn signals. With blacked out housing (painted black with clear coat), the white looks bright, but the amber is not up to par in broad daylight (on a sunny day) IMO.
These new lights are supposed to put out 600 lumens in white and 430 in amber. Should be BRIGHT!
EDIT: Will add pictures of these installed in black housings when I receive them (hopefully Saturday). For now, pictures of these installed in Depot halo headlights on page 5 here: https://www.cobaltss.net/forums/appe...30/index5.html
these look niceee
i currently have the 92 led ones (orig had 60 and had problem and vleds sent me 92 in replace) and for some reason im having a problem with the passenger one.
maby i have to take it out and plug it back in
these new ones will require resistors correct? they look nicer too!
judging by the heat sink on those things, they should be pretty powerful. Bout time the aftermarket plug and play bulb community starting getting some quality, high power leds instead of the cheap junk that makes up 99% of the market. I'd love to pick up similarly made bulbs for brake/turn signal/reverse.
these look niceee
As far as brake/turn signals - they have those available on the site too. They're a bit pricey, but way worth it IMO if you have the stock housings.
As far as brightness, at 600/430 lumens they'll be the brightest LED turn signal/parking light on the market! The white is 60% of stock low beam lumens!
$100? Are the including a BJ with them?
If they truly look as good as they do in the vid, I might be interested in some of them. A lot of the cheapo bulbs look like that, cheap. How in the hell do these work? Are the wires coming off the bulb used for a separate power source?
So does that mean no cutting into the stock wiring? The resistor will be attached with the bulb?
Will these work for the turn signal that are also used DRLs?
According to them, the inline resistors will be plug and play, no cutting required.
And, IIRC, they will work with both regular running lights and running lights that use high filament to shine white and only switch to amber when turn signal is activated.
EDIT: just found this on their FB page (answer to a customer)
Originally Posted by VLEDs
V-LEDS Don Yes! The V3 is stable running 24/7 on the high output mode. The entire structure of the bulb is a heat sink that draws the heat away from the LEDs. This keeps it running at a very low temperature. Stability and long life was a primary goal. Our exclusive white/amber V3 Switchbacks will also work in your DRLs. When the parking light (low) or DRL (high) is on the color of the bulb will always be white. When the turn signal is applied the white shuts off and only the amber will come on. There is no other bulb in the world that can do this!
The wires coming off attach to adapter of your choice.
Not sure, but since my front signals are already wired up with resistors, I'll use those for now.
I would too, if my turn signal housings weren't blacked out.
Yes, I asked that exact question on their FB post, here's their answer:
So my guess is I got another month to wait. But, from what it looks like, they're worth the wait. They're brighter than stock lights for sure. I'll post up a picture of them comparing them (off their FB page)
Originally Posted by V-LEDs
We do not have a firm date at this time, but we estimate mid November for amber and red. White, and switchbacks will be closer to the end of November, first of December. We will post the date as soon as we know it.
Here are the comparison shots mentioned in the post above:
These are obviously single color amber V3s (not switchbacks), but they show the difference. White light on the switchbacks should be even brighter.
im 99.9% sure that standard is what we have but figured id ask.
Just spotted this on youtube, can't wait for mine to arrive:
V3 Triton LED system installed FR-S walk around by VLEDS - YouTube
