volt gauge
1. I got my wire from a totaled cobalt from my work that came in. (I work in a body shop), but any auto parts store should have it.
2. I used some bolt under the dash for my ground, next to the A pillar.
3. I got a add a fuse and connected it to my windshield wiper fuse.
wtf is add a fuse lol but still wanna know about what wire to use for an liymantion one cause i dont want the blue led light on all the time if i dont have to
NVM u just got it haha...
Wait you should have a :
1-direct voltage power cable that hooks up to your battery or any direct 12v source
2- power wire that connects to a switchable 12v souce thats only activated when the car is on like the power windows switch " this will control the on and off "... Do this !
Run a power power from the window switch fuse from the fuse box on the passenger side then run it all the way to ur gauges and connect them to that...thats how i have mine hooked up and they will light up every time the car is on and turn off whenever the car is off.
The illumination is only to dim them or brighten them, just leave that unhooked " put electric tape on it so it doesnt touch anything else "
Follow this How to. You have the same exact gauge.https://www.cobaltss.net/forums/how-...tmeter-135541/
yeap and a ground close to the gauges
ive never seen them around any auto shop here,,y dont i just tase one of the empty spots in my fuse panel
and then my ilumnation wire will work as well with this into the power windows
They have them trust me. Im not to sure on this ilumination wire hopefully someone else can tune in. Just follow that how thats the same exact gauge you have and he tapped into his dimmer switch for the light.
i know with the gauge i was reading that the is a main 12v power and a fround trhe nanother power for the ilumantion...maybe with ill do it tie it into my p.w on the pass side but the ground close to the a pillar, and for the iliumantion. put a jumper wire from the main 12v on the guage to the illumantion terminal u think????
Sl0wbaltSS
Nov 21, 2018 11:11 PM
z28addiction
Sep 28, 2015 12:03 AM
