what the hell is the problem!!
Old Apr 4, 2008 | 08:23 PM
blk ss/sc 1's Avatar
ok i have the first gen projectors and have had them for about 5 months.. first time my right headlight burnt out - replaced it ...then about 3 weeks ago my left headlight burnt out - so i got silverstars to replace both of them,,, now tonight my right one burnt out agian.. WTF is the problem? i'm pissed.. is there something i could have done when wiring them up or am i just having bad luck with these things???
Old Apr 4, 2008 | 11:12 PM
biniecki's Avatar
I know that your not the only one that has had problems with those things eating bulbs. To me it sounds like you are you are getting voltage spikes or just too much voltage in general to the lights which is burning them out a lot quicker than they should be. If you have a volt meter I would test the voltage going to the bulb plug and see what you are getting. You may need to put a resistor in to limit the voltage further or something to filter out spikes if that is the case.
Old Apr 4, 2008 | 11:19 PM
silentd's Avatar
the cases for them make them heat up much hotter. which = less life
Old Apr 5, 2008 | 12:19 AM
Xavipheus's Avatar
Its ridiculous Ive gone through at least twenty bulbs. I finnaly put my stockers back in. I feel like the only way to fix it is with a HID kit because I think there might be a voltage problem, but again I have no idea. It so random, sometimes they would last weeks, days, hours, months. So sick of throwing so much money into them...ughh.
Old Apr 5, 2008 | 09:11 AM
yea im pissed.. i just spent $40 on silverstars thinkin that maybe they'd last a little longer
Old Apr 5, 2008 | 09:22 AM
liolixli's Avatar
Same thing, put my stock back in. All the bulbs in mine burnt out 3 times and I gave up on them. I liked the way they looked, but never was happy with the visibility while driving anyway.
Old Apr 5, 2008 | 10:20 AM
TheCaptain's Avatar
I haven't had any problems with mine, but i have HID lows. Silverstar highs.
Old Apr 5, 2008 | 10:23 AM
DoubleLP's Avatar
Did you happen to touch the Silverstar bulb before putting it in??
Old Apr 5, 2008 | 10:45 AM
originaladrian's Avatar
this sounds like a dumb question, but he is totally right, oil from your hands will cause the bulb to heat up unevenly.
Old Apr 5, 2008 | 01:21 PM
lol yea im not dumb.. and like i said it's the third this has happend in 5 months.. it doesnt make sense to me
Old Apr 5, 2008 | 05:13 PM
Switt23's Avatar
I would just save your pennies and get an HID Kit. They require more power to turn on, but burn cooler. So if the problem is the gases getting to hot and burning out that way, HIDs would be a reasonable fix.
If it's voltage, he's gunna be popping them left and right, not one every few months.
Old Apr 5, 2008 | 06:04 PM
i just replaced it with another silverstar. either im givin up next time or ill finally dish out the 150$ for hids.. do the projectors require a retrofit for hids though? i dont wanna blind anyone coming towards me
Old Apr 5, 2008 | 06:41 PM
Maven's Avatar
Are these things wired to turn on both bulbs on high beams? If it does, this is most likely the issue.
With both bulbs on there is reduced resistance in the headlamp circuit, which results in increased AMPERAGE, this is what is blowing the bulbs.
If they arent wired like this, then its either heat, oils, or defective bulbs. Its highly unlikely(damn near impossible) that your getting a voltage spike that is blowing out your headlight bulbs and causing no other issues.
Old Apr 5, 2008 | 06:56 PM
TheCaptain's Avatar
both highs and lows only come on if you have your lows on, and hold "flash to pass"
turbochargedss2012
Sep 20, 2023 12:17 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
