whats up w/ my psngr low beam?
my passenger side low beam would not work sometimes. i would turn the lights off and then back on and it would work. i was told to power the ballasts directly using a relay rather than thru the stock wiring and it would fix it. well, it didnt. anyone else have this problem? any other ideas? btw i have gen 1's with 6000k 50 watt hid's
1 Post
Swap the bulbs (Just the bulbs... not the ballasts) and see if the issue ends up changing to the driver side. If so, then the bulb is on its way out and dying. If the problem persists on the passenger side, swap the ballasts around and see if the problem goes to the driver side. If so, then one of the ballasts is on its way out. If that doesn't help, then you can assume it is a wiring issue with the car and then use a battery fed harness to fix the problem.
I ALWAYS reccommend using relays. They ensure that your ballasts recieves the power it needs without overstressing the stock wiring. Also, when you use a harness, it is much easier to configure it so that the low beams will stay on with the high beams (If you have the projector housings). Quad Beam projector high beams = sexxxxxxxxxx.
i have them powered by the battery using a relay, and i also have the ultimate high beams mod, and yes it is the sexxx. it makes **** so bright its ridiculous
i dont think its either the ballast or bulbs b/c im on my second set of both and its always been just the passenger side that was the problem
1 Post
i didnt have a relay harness with the first set of bulbs and ballasts. i had my second set installed for about a month or so then i got the relay harness. if i need to get a new stock headlight wiring harness where might i find one? gmpartsdirect.com doesnt have them in stock and i cant seem to find them anywhere else online.
DANRICKARD
10-01-2015 12:08 AM
importkiller
09-30-2015 07:18 PM
