why is going wingless so difficult, help needed!!!
Old Apr 29, 2007 | 01:05 PM
Gamebay11's Avatar
Well I decided I wanted togo wingless, so I started out this morning. Well I took off the bolts, then using fishing line, goo gone, and a hair dryer, I have made only a little progress. I am looking for any tips or tricks todo this. That black adhesive is just resticking to itself everytime I cut through it with the fishing line. Help me please.
Old Apr 29, 2007 | 01:09 PM
Jase's Avatar
When i put my insert in.. I used the line with a screwdriver tied on both ends, and created sorta a noose. i wiggled the screwdriver with one hand cutting and pulled with the other.
Im not sure about between the trunk and the wing though
Old Apr 29, 2007 | 01:11 PM
zomghax's Avatar
Took me a couple of hours of struggling with mine to get it off. I also dented the trunk lid slightly on the left side, from putting too much pressure on the wing when trying to remove it.
Old Apr 29, 2007 | 01:38 PM
Gamebay11's Avatar
yeah it looks like that with mine so far too. Man that glue sucks. Oh and do you have pics of your trunk now.
Old Apr 29, 2007 | 01:43 PM
Toronto SS's Avatar
it took along time to get mine off the ss/sc base is huge... it takes a lot of heat and time... then when youre done you'll have huge scratches where the wing used to be lol
Old Apr 29, 2007 | 01:49 PM
red2006SS's Avatar
i used the fishing string also and it took a awhile. i ended up doing only so much and just started pulling and i used a scraper. the one you would use to lay putty or something on. you just have to be careful you dont scratch the trunk. if you try to leave some glue between the scraper and trunk you may have luck. it sucks though it takes some time to make it come out good.
Old Apr 29, 2007 | 04:12 PM
Gamebay11's Avatar
Update, well i got the wing off and have a decent amount of glue still on it. I currently have it soaking in goo gone to loosen it some. If that doesnt work, what are some suggestions? That and how did you guys plug your holes, I was thinking of using plastic push pin clips and painting the head orange to match.
Old Apr 30, 2007 | 01:01 AM
GatorEngineer34's Avatar
"3M adheasive remover" is much better than goo gone
Old Apr 30, 2007 | 01:03 AM
Red06LS's Avatar
i dont think your suposed to use goo gone on paint!!!!
Old Apr 30, 2007 | 01:20 AM
BACK2GM's Avatar
Its easy with two people ;p and use 3m #4 adheasive remover.
Old Apr 30, 2007 | 02:36 AM
red2006SS's Avatar
you can use goo gone on paint. its says its for tar and stuff too. i used it on some of my stuff before and i never had a problem with it. as for holes i have some auto zone plugs in temporarily till i can get the holes welded in and painted. i just used a silicone also so it does not leak. its not really adheisive silicone but it works well.
you can probably sit there and peel off the glue not that you want to hear that but it does work it just takes a little and starts to hurt the fingers but at leaset you will have no scrathes or anything messing with your paint. good luck on getting it off
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
