Wire Tuck (with pics)
Old Jul 19, 2015 | 09:39 AM
  #251
Axelthered05's Avatar
what is this on my clutch cable and do i need it?
I have the other cable in place and its really a tight fit so im wondering it it is a piece i need
Old Jul 19, 2015 | 09:43 AM
  #252
according to gm's part number description it's a secondary reservoir, I think this is the problem I'll keep you guys updated, the car is running and idling so when I can finally get it in gear I should be "done"
Old Jul 19, 2015 | 10:13 AM
  #253
JapEatr's Avatar
South Central *********
Originally Posted by Axelthered05
yeah the wheels turn in neutral, and if i roll the car in gear with it off the engine rotates with it.
im also going to try the old clutch cable before i pull the trans again it has a weird piece on it which has me curious
Either flywheel bolts are contact pressure plate or pressure plate backwards
Old Jul 19, 2015 | 10:33 AM
  #254
I'm sorry let me be clear about that I thought you were asking if I could freely rotate the wheels when in neutral. The wheels do not move with the engine when in neutral, there is no mechanical connection unless I'm in gear
Old Jul 19, 2015 | 05:58 PM
  #255
Omiotek's Avatar
to my knowledge its not possible to put in backwards unless your a total idiot. the pressure plate goes one way.... even the clutch disk cannot be put in backwards. the pressure plate wont sit flush with the flywheel if its in backwards.
Old Jul 19, 2015 | 07:23 PM
  #256
That's what I thought too but when nothing else is wrong you start to second guess yourself lol
Old Jul 19, 2015 | 08:51 PM
  #257
I put my clutch in backwards the first time... Luckily i realized before i put the trans back in.
Old Jul 19, 2015 | 10:25 PM
  #258
JapEatr's Avatar
My ARP flywheel bolts ZZP sent me hung up on the pressure plate and caused a similar situation
Old Jul 20, 2015 | 11:21 AM
  #259
welp its still not going into gear so the trans is coming out today
Old Jul 20, 2015 | 01:22 PM
  #260
sc4door's Avatar
Not that it really helps you right now, but I left that piece out of my clutch line too when I put in a stainless line and never had any issues and I'm not sure what it is either
Old Jul 20, 2015 | 05:08 PM
  #261
ok so as it turns out I put the clutch puck in backwards, luckily the clutch is undamaged so im on the right path now
Old Jul 20, 2015 | 05:19 PM
  #262
JapEatr's Avatar
Boom, seen it happen before
Old Jul 20, 2015 | 07:19 PM
  #263
double clutch's Avatar
Bravo
Old Jul 20, 2015 | 09:54 PM
  #264
Glad im not the only one
Old Jul 23, 2015 | 12:54 PM
  #265
ok so trans was ripped out, clutch was reinstalled properly and now is back in the car, I'm able to get it into gear but its still stiff, im going to get some help to properly bleed the clutch tomorrow, other than that I'm not seeing any fluid leaks now *knock on wood* and i have a small issue with the passenger headlight to deal with because its not working the way it should but it looks like im just about done,
Old Jul 23, 2015 | 12:59 PM
  #266
nice. reminds me i think i got a trans leak to take care of
Old Jul 23, 2015 | 01:03 PM
  #267
Dipped_Cobalt's Avatar
oh oh...seems too much trouble at the end of the day. my 2 cents.
Old Jul 23, 2015 | 02:00 PM
  #268
umrdyldo's Avatar
We all knew this. The outcome looks amazing but hot damn it's not worth the trouble.
Old Jul 23, 2015 | 06:03 PM
  #269
well i dont know about that, its super easy to service everything with the fuse box out of the way so to me it was worth it
Old Jul 24, 2015 | 11:59 AM
  #270
all the hours you have put into it...was worth it? it makes it easier to work around...but how hard can it be to work on our engines...compared too all hours of labor you did?
Old Jul 24, 2015 | 12:07 PM
  #271
It looks soooo ******* clean tho, totally worth it
Old Jul 24, 2015 | 12:11 PM
  #272
the look is 2nd to none. very awesome looking...
but now he has issues with headlights lol
Old Jul 24, 2015 | 03:40 PM
  #273
omg I laughed so hard at this
ok so the problem with the passenger headlight turned out to be the grounding pin on the headlight connector. I apparently damaged it shoving the electrode of the volt meter into it when I was sorting out wires. I had to remove the pin, reshape it so that it would connect and now it's working perfectly. I went ahead and double checked that all the turn signal and hazards work along with the brights and running lights. currently the car is on the battery charger
Old Jul 24, 2015 | 03:47 PM
  #274
laughed so hard? I don't even know what I said that would be so funny, like I said, and others agree, looks good, but TOO much work at the end of the day, my 2 cents.
the ends do not justify the means, in my eyes but keep on truckin. I don't pay for your mods.
Old Jul 24, 2015 | 04:36 PM
  #275
sc4door's Avatar
Looks good. Don't forget your o2 sensor
