Wire Tuck (with pics)
Old Jul 4, 2015 | 09:17 PM
  #226
Any luck with those tb codes?
Old Jul 5, 2015 | 08:58 AM
  #227
Axelthered05's Avatar
no i have not had a chance to tinker with it since Saturday morning, i start with it again Monday morning
Old Jul 5, 2015 | 12:36 PM
  #228
ItalianJoe1's Avatar
Try another TB, i've seen them have some strange issues when they fail.
You're sure it's wired up properly? Both that and the gas pedal?
Old Jul 5, 2015 | 04:51 PM
  #229
Anyone know the voltage range of the oxygen sensors? My torque app is telling me their both .5v constantly and only a .01 max fluctuation between start up and when it dies. I'm going to confirm their voltage tomorrow with the fic but it looks almost as if the ecu isn't getting a signal from them, any thoughts or things I might be missing?
Old Jul 5, 2015 | 06:50 PM
  #230
Try unplugging them, you dont need o2 sensors to run. .45v is the bias voltage that should be there when the engine is off. When the car is running they should be switching between 0 and 1000mv.
Old Jul 6, 2015 | 06:36 AM
  #231
I will try that, on another note i did a pressure test today and dont have any vacuum leaks to speak of so its not that
Old Jul 6, 2015 | 10:36 AM
  #232
well I'm not sure what exactly is up I got the car running by throttling it until it stayed on by itself, let it warm up to operating temp before shutting it off I haven't tried to start it again since then but I'm going to try and start it with the FIC controller in place next
http://vid1061.photobucket.com/album...pshs24xzrg.mp4
and just fyi I should have said a code for VSS and power steering was on the display on the dash
Old Jul 6, 2015 | 06:34 PM
  #233
update: i cant get the car in gear and i have break fluid coming from the transmission, looks like my TOB is dead i should have replaced it as its the original and the cars over 100k now *sigh* out comes the transmission again
Old Jul 6, 2015 | 07:18 PM
  #234
exninja's Avatar
Did you do anything to the transmission other than remove the clutch line? If so, double check the distribution block connection before you pull the trans.
Old Jul 6, 2015 | 10:38 PM
  #235
mines an f23 i dont have the distribution block like the SS guys have
Old Jul 6, 2015 | 11:05 PM
  #236
YelloEye's Avatar
Is it coming out at the clutch line or near your ABS system?
Old Jul 6, 2015 | 11:23 PM
  #237
there are no leaks in the breaking system, i checked all over the place, the fluid is pouring out between where the transmission mounts to the engine
Old Jul 7, 2015 | 01:01 AM
  #238
SSfamilywagon's Avatar
Great progress and job on the project. Hopefully you get things sorted out.looking forward to the end result. I have plans of relocating the fuse box on our car to go with our mini wire tuck I did already.
Old Jul 7, 2015 | 08:54 AM
  #239
07blackg5's Avatar
Slobodan Milošević
tob had to have failed pretty bad. there are no fluid connections until outside the trans
Old Jul 7, 2015 | 10:51 AM
  #240
well with the 2.2 TOB they have a large plastic pipe instead of a metal one and a distribution block like the ss has, I know it got dropped a few time in the 4 month period it was out of the transmission so it might be completely my fault that its broke but oh well i ordered a new one from CED this morning
Old Jul 7, 2015 | 11:10 AM
  #241
07blackg5's Avatar
Slobodan Milošević
i'm 2.2 as well. l61 crew
Old Jul 7, 2015 | 11:24 AM
  #242
exninja's Avatar
Ah, I'm even less familiar with that. I thought that the integration of the slave a TOB was the silliest thing ever, but now I find out that the F23 with just plastic lines is even worse
Old Jul 7, 2015 | 10:38 PM
  #243
I saw an F23 slave blow out the plastic plug on it, I have pictures somewhere but you will see it when it's removed.
Old Jul 18, 2015 | 09:49 PM
  #244
well ive replaced the tob but same thing still wont go into gear, next im going to have to check the clutch
Old Jul 18, 2015 | 09:55 PM
  #245
Wont go into gear if engine is running? If tob is good and not leaking it could be the master
Old Jul 18, 2015 | 10:46 PM
  #246
Yeah I thought it could be that to but I know that pumping the clutch petal does indeed push fluid through the line and ive swapped out the master cylinder itself for another completely unrelated reason so I don't think its that either :3
Old Jul 18, 2015 | 10:47 PM
  #247
I'm actauly afraid I might have put the clutch together wrong, I'm pretty sure I assembled it properly but now I'm second guessing myself
Old Jul 18, 2015 | 11:44 PM
  #248
JapEatr's Avatar
South Central *********
Jack front end up, in neutral does the wheels turn?
Old Jul 19, 2015 | 12:01 AM
  #249
Damn dude i feel so bad for you right now!!
Old Jul 19, 2015 | 09:31 AM
  #250
yeah the wheels turn in neutral, and if i roll the car in gear with it off the engine rotates with it.
im also going to try the old clutch cable before i pull the trans again it has a weird piece on it which has me curious
