Autocross and Road Racing Road racing is not “street racing”
3 wheelin
Old May 16, 2011 | 05:46 PM
madcitySS's Avatar
3 wheelin official?
I was at a smaller local event here where I use my street tires and a friend managed to get a shot of this.
I thought it was neat, and people are always shocked with the times the cobalt runs... good showing for the car
BPacak's Avatar
Vtec Rep
nice haha.
Old May 16, 2011 | 05:47 PM
outtamymind's Avatar
lol nice. way to push it through the corners
Old May 16, 2011 | 05:57 PM
deebsr6's Avatar
wouldn't r-comps make this even worse? looks like its time to adjust your suspension to get that wheel down and keep it getting grip. Definitely looks cool though
Old May 16, 2011 | 06:04 PM
madcitySS's Avatar
the car is stock so no real adjusting I can go. R comps would make that worse, but the inside rear tire doesnt do a lot on a front wheel drive car... well compared to the other 3.
Old May 16, 2011 | 06:09 PM
deebsr6's Avatar
ah alright then it may be time for a rear sway. May not seem like it will do a lot but by keeping that tire down you will even out the weight on the front too utilizing both front tires better, which will help the car a lot. Just dont go to big cause you still want some independence.
Old May 16, 2011 | 06:13 PM
madcitySS's Avatar
Well im racing the car in D Stock so I have to keep it stock for the most part. Cant do a rear sway bar but I can do a front, dont think I will tho cause I like the cobalt in its stock form, and I dont need it to push or understeer anymore than it already does by putting a front on lol. I had my 07 STI specd out for an autoX class and that this was on a rail
Old May 16, 2011 | 06:17 PM
deebsr6's Avatar
alright yeah if your trying to keep in stock class then its just gonna be how it is which isnt bad at all. What setup did you have on your sti? I have an 05 right now that I am gonna be working on the suspension next
Old May 16, 2011 | 06:20 PM
Wangspeed's Avatar
Inside rear on a FWD car doesn't need to be on the ground while cornering hard. VW and Honda learned this a long time ago. Honestly, most of the time you can't even tell when you're driving. You might get a little puff of smoke if the wheel stopped spinning, when it comes back in touch with the ground, but usually it's a non-event.
Looks great for spectators though
Old May 16, 2011 | 06:24 PM
madcitySS's Avatar
under braking it might need to be tho... on our cars anyway. I think thats why I have hit ice mode so much on rcomps. braking hard when turning will cause the inside rear to lift and im guessing freak the ABS out since one wheel is locked up.
Not in this pick tho, was able to keep speed in the slalom
Old May 16, 2011 | 06:27 PM
madcitySS's Avatar
I used RaceComp Sways front and rear, RaceComp T2 coilovers with custom spring rates, Turbo back and 17X9 wheels with 245-40-17 (per class rules on tire size)
Old May 16, 2011 | 06:32 PM
deebsr6's Avatar
nice car. with my engine mods I can run whatever I want pretty much since I am in SM. I just ned to decided what I want to run.
Old May 16, 2011 | 06:38 PM
frankie's Avatar
wow, great picture!!
Old May 16, 2011 | 06:42 PM
tglems's Avatar
IIRC you can run some mods and still stay in D-stock, depending on how many points it adds. The 'balt definitely does well in D-stock, but if you could stay in D-stock and put some pedders springs on there you would be golden. You'd easily shave a couple seconds off your times for most 40ish second courses.
Either way, sweet pic!
Edit: NM, you wouldn't stay in stock class, you'd have to move to street tire to be most competitive. Well, at least you could get some better tires than the stock conti's that would help a bit. The r-comps would let you push it a bit harder, which would make the rear tire lift a bit more but would def give you better times.
Old May 16, 2011 | 06:49 PM
madcitySS's Avatar
Yeah I'm pretty content running the cobalt stock until I sell it to et another s2000 and build that for STR
Btw nice pick, packers FTW
Old May 16, 2011 | 06:53 PM
tglems's Avatar
Thanks man, I noticed you were up in Madison. I'm down in AZ now but I was born in Green Bay and lived in Milwaukee too for a bit.
Old May 16, 2011 | 10:49 PM
keiserX13's Avatar
Thats sick!
Is that ur real plate? or Photoshop magic?
Old May 16, 2011 | 10:52 PM
AaronJ's Avatar
Thats sick!
That's his real plate, I've seen it in person.
Old May 16, 2011 | 10:53 PM
09Sp0rt's Avatar
I was expecting to read this and see ATV's
Old May 16, 2011 | 10:55 PM
keiserX13's Avatar
That's sweet, Fitting
couldn't tell don't know what Wisconsin's letters look like LOL
Old May 16, 2011 | 11:26 PM
tglems's Avatar
Speaking of plates, our plates are cousins. Mine is "SLO4DR"
Old May 17, 2011 | 12:29 AM
YelloEye's Avatar
This.
I need to get mine out on the autocross track this year.
Old May 17, 2011 | 12:52 AM
deebsr6's Avatar
i like your style
Old May 17, 2011 | 10:55 AM
madcitySS's Avatar
hah nice! I almost went with "WRTYVOD" :p but didnt want to bring thats upon the car lol
and i still have my warranty lol
Old May 17, 2011 | 10:59 AM
jboogie's Avatar
Nice numbers! HAHAHA
