Autocross and Road Racing Road racing is not “street racing”
Air Splitter Installed . Finally
Old Mar 18, 2012 | 10:13 PM
Sox-Fan's Avatar
Got Brakes?
Originally Posted by mongorat427
Hmm if that was the case wouldnt the car overheat sitting in traffic. Will have to study that a little more
It has up to two fans running when it is sitting. When you are moving I believe the fans are pretty well useless and you'll need airflow.
Old Mar 18, 2012 | 10:14 PM
05Slowline's Avatar
could make the fans run all the time with hpt but it's still prob going to suffer and be annoying as **** at the same time
Old Mar 18, 2012 | 10:19 PM
mongorat427's Avatar
The fans only come on at a certain temp anyways. It might do something like create a bit of suction to help pull more air in through the grill. Im sure it wouldnt be blowing air from under the car with dust dirt etc.
Old Mar 18, 2012 | 10:20 PM
Ha Ha right. Im on E85 so I allways run around 185. Never see 200
Old Mar 18, 2012 | 10:27 PM
Sox-Fan's Avatar
Got Brakes?
Oh really? Ever seen a grille on a C5? The ONLY place they pull air is from underneath where there is dust, dirt, grass, leaves, etc. I can almost give you a guarantee that fans do not contribute a darn thing at road speed and the air dam contributes far more than they do.
Of course you can prove it easily enough.
Old Mar 18, 2012 | 10:32 PM
05Slowline's Avatar
yea it's already been done, was a few redlines that decided they were gonna take theirs off then wondered why their ect was sky high just cruising but if you wanna try it go for it lol.
Old Mar 18, 2012 | 11:27 PM
Read this. (NASCAR race cars have air dams. Any number of reasons come to mind:
To create aerodynamic down-force and thus improve the grip of front tires.
To make the car faster by reducing drag (by moving air out to the sides before it creates turbulence underneath.)
To improve gas mileage.) These seem more plausable reasons for the air dam.But their air dams are right in the front. Ill have to look a a couple other cars to see what they have
Old Mar 18, 2012 | 11:43 PM
Originally Posted by slowswap
Not unless it's close to the ground. It's to high up. And even when its close to the ground, without an under tray, you won't reep anywhere near the benefits you should.
What do you do with the factory air dam when you use an under tray ?
Old Mar 19, 2012 | 12:05 AM
Sox-Fan's Avatar
Got Brakes?
As you pointed out, Mongo. They have air dams and splitters up front to keep air from entering underneath the car creating turbulence and lift, and additionally, to promote downforce.
GM put an air dam under your radiator to channel air up and through the radiator.
Easy enough to test. Couple minutes tops and it is off. A sheet of plastic and 5 minutes with some wire ties mocks up a simple, crude pan. Take it for a drive, see what happens. Investment is less than an hour and a handful of wire ties.
Old Mar 19, 2012 | 12:13 AM
bobbyjohn681's Avatar
less drag underneath car by creating a higher pressure underneath, therefore letting it hunker towards the ground (low pressure moves to fill high pressure), make a rear splitter too with a couple vents on top like they have for evos and ****, jus warm the plastic up with a propane torch and bend till desired, if you want to go as far as creating a under pan to clear exhaust and susp depending on how serious u take ur auto crossing, it would help also, the smother the air has to flow under the car the more downforce u have for cornering harder @ higher speeds, higher downforce= higher traction son, look at lemans cars for info on this if need be, some vortex gens help on top of rear window and under rear bumper to like on the evo mr's, create low pressure post rear window for better fuel economy and helps slighlty in cornering by creating a sail like effect and holding the ass end in line, dont look like much but every bit helps
info on vortex gens is all here, Vortex Generators for Enhanced Aerodynamics :: Sigma Automotive
fab some canards also, they help hold the front end down in straightaways, keep at it, n post results on street (fuel economy and such) as well as at the track as the build moves on, once u got prototypes i will prolly move towards ur finished product with some cf for weight and looks, well mostly looks, u get the point lol
Old Mar 19, 2012 | 12:18 AM
  #36
You're not doing autocross right then.........
the unnecessary criticism doesn't help him progress with the idea one bit dick....specially after he said street/track car, i actually in for results to see were it can be improved w/ adjustment to make it work and still have ground clearance for the street if he so chooses to remain a street car, advise rather then slammin the ****** to the pavement is what hes really lookin for im sure
Old Mar 19, 2012 | 12:30 AM
  #37
slowswap's Avatar
lmao. he said he built the lip to hit cones. i mearly responded with a much to subtle for you joke.
An undertray should extend the whole length of the car. You biggest gains will be seen making it go to cover the whole subframe, in theory. Properly placed louvers can help remove heat from the engine bay and provide a marginal downward suction to the road by removing air pressure in the engine bay.
A well setup cooling system should be fine without the air damn. It couldn't hurt to add some directional directing behind the bumper to channel air the radiator, but I don't feel its of the largest concern.
But again, to notice any actual effects from any of these mods, the car needs to be hugging the ground. There's much better ways to achieve better handling then through aerodynamics in this scenario.
And if you feel you hit cones at times, a clear bra is a great way to keep the paint looking great. I haven't seen a cone crack bumpers from a light hit.
Old Mar 19, 2012 | 12:34 AM
  #38
deebsr6's Avatar
nevermind didnt read all the way and want to stay out of that debate.
looks good now time to find a windtunnel for testing. good luck lol
Old Mar 19, 2012 | 07:48 AM
  #39
Looks like the Vortex generators would really help. Read several good articles allready. Simple to install also
Old Mar 19, 2012 | 01:10 PM
  #40
Mark Aubele's Avatar
Looks good Jeff. Are you trying to stay legal in any reasonable class or are you just going to extend it back to the rear of the subframe? As high as it is I doubt any real reduction in lift is going to be seen unless it is extended far back, but some oems claim to reduce lift with tiny "splitters" so who knows. I think your main customer is going to be buying it for looks any way when it comes down to it, and when it comes to that it fits the bill.
Old Mar 19, 2012 | 01:17 PM
  #41
Im going to drop it back down so it 2 or 2 1/2 inchs off the ground now that the Drag racing experiment is over. The coilovers make it easy to adjust. I have a piece on material that Im going to make the underplate with. Left over from making 2 splitters. Think it will matter if I remove the little air dam ?
Old Mar 19, 2012 | 01:35 PM
  #42
I wouldn't remove it unless you are bringing the splitter all the way to the rear of the subframe, at which time it obviously won't be serving any purpose. Not sure how much it will be doing with the splitter that low either.
Old Mar 20, 2012 | 12:58 AM
  #43
make sure u angle em evenly opposite as they state to get the full proper effect from them
Old Mar 20, 2012 | 01:27 AM
  #44
BlueBolt66's Avatar
removed my air dam about three years ago. No problems or drastic changes except the lack of scraping plastic sound when entering a driveway
Old Mar 20, 2012 | 06:01 AM
  #45
Old Mar 20, 2012 | 06:47 AM
  #46
05Slowline's Avatar
sure ya did
Old Mar 21, 2012 | 10:53 AM
  #47
RoadconeTuning's Avatar
someone has a video on youtube of a tuft test with vortex generators on a few cars... i doubt you'd see any difference on a cobalt with the shark fins on the roof, our rear glass is at a pretty flat angle...
Old Mar 21, 2012 | 10:59 AM
  #48
07LSJ's Avatar
i think it looks pretty good
Old Mar 21, 2012 | 12:58 PM
  #49
I was thinking under the rear lip. I saw a couple good articles on those and they really work. Im looking at adapting a blade style spoiler like John Powell has on his ride . I just need to find the proper angle.
Old Mar 22, 2012 | 07:15 PM
  #50
slowswap's Avatar
Fixing the rear spoiler is an excellent first step. It doesn't create downforce from factory....
