Autocross and Road Racing Road racing is not “street racing”
Air Splitter Installed . Finally
Old Mar 18, 2012 | 04:21 PM
mongorat427's Avatar
Well Finally installed my Air Splitter. Its 3.25 inchs wide at the very center on the nose and just needs touched up on the corners with the file to remove a couple sharp edges. The leading edge can be adjusted up and down about a half inch in either direction . Heres some pics
Old Mar 18, 2012 | 04:27 PM
SKCobalt's Avatar
What material did you use to make it?
Old Mar 18, 2012 | 04:32 PM
keiserX13's Avatar
Looks good
what are the braces made from?
Old Mar 18, 2012 | 04:34 PM
TX.SS.TC's Avatar
Looks good
x2
Old Mar 18, 2012 | 04:36 PM
1 SLOW SS's Avatar
Jeff texted you on how much this cost to make I want something basically identical except in carbon fiber and a little longer near the lip by the inner fender your seems to get thinner
Old Mar 18, 2012 | 04:37 PM
BlkWdoSS's Avatar
looking good, what material is it?
l8r,
PD
Old Mar 18, 2012 | 04:39 PM
idk just not feeling it.
Old Mar 18, 2012 | 04:41 PM
slowswap's Avatar
It would be useful if it was about an inch off the ground. Unnecessary weight and messing with the aerodynamics in a bad way.
Old Mar 18, 2012 | 04:51 PM
Its made from ABS $60 a sheet from Curbull Plastics and is stiff but flexable. 1 inch off the ground will never work on the street especially in the Northeast . I use my car for more than just autocross and road course although I do lower it when I go to the track. I got the adjusters from track Dog Racing as well as the Nylon breakaway bolts.
Old Mar 18, 2012 | 04:53 PM
I do mostly Autocross where it will be banging cones instead of my lip.
Old Mar 18, 2012 | 04:54 PM
Looks good
Anodized Aluminum Track Dog Racing
Old Mar 18, 2012 | 04:58 PM
It sticks out on the side just enough to hit the cones which Im very good at. It ends even with the edge on the wheel well opening.
Weight 2 pounds with screws
Last edited by mongorat427; Mar 18, 2012 at 04:58 PM. Reason: Automerged Doublepost
slowswap's Avatar
You're not doing autocross right then.........
Old Mar 18, 2012 | 04:59 PM
I still hit a cone now and then.
Old Mar 18, 2012 | 05:06 PM
Geo_SS's Avatar
looks good man
Old Mar 18, 2012 | 05:12 PM
Originally Posted by Geo_SS
looks good man
Thanks. There is enough material to make 2 of them in each sheet . Plus still a lot left after that to make other stuff. Carbon fiber is in the $400 range for a sheet of .060 thick. To pricy to be smackin cones and what with
Old Mar 18, 2012 | 05:14 PM
1 SLOW SS's Avatar
You should make me one I'll come pick up! How did u attach it underneath! Pm me if you wanna make me one and how much
Old Mar 18, 2012 | 05:22 PM
I took the bumper cover off which made working on it a breeze. After I had it lined up the way I wanted it I drilled a hole on each side close to the wheel well opening. I then removed the lip and drilled the rest of the holes. The braces were installed after I got it back on the car.
Old Mar 18, 2012 | 05:23 PM
redcobalt07's Avatar
Question is does it actually help improve aerodynamics?
Old Mar 18, 2012 | 05:27 PM
slowswap's Avatar
Not unless it's close to the ground. It's to high up. And even when its close to the ground, without an under tray, you won't reep anywhere near the benefits you should.
I guess it would depend on a few things such as how low the car is and the angle its set at. As for autoX it wouldnt do much except protect the lip from cones. I looked at the ones I saw at the track and online a they all look very similar
Old Mar 18, 2012 | 05:30 PM
Im working on the under tray as we speak. Need to make a few measurements. Air dam would need removed also. I have enough material left over. How far back do you think I should go ?
Old Mar 18, 2012 | 09:50 PM
Sox-Fan's Avatar
Got Brakes?
I'm under the (perhaps mistaken) impression that the the air dam does pull some amount of air and routes it into the radiator. Will making an under tray and removing the air dam cause any cooling issues?
Old Mar 18, 2012 | 09:53 PM
05Slowline's Avatar
yea you don't wanna remove the air dam lol.
splitter looks good
Old Mar 18, 2012 | 10:04 PM
Hmm if that was the case wouldnt the car overheat sitting in traffic. Will have to study that a little more
