Autocross and Road Racing Road racing is not “street racing”
Air Splitter Installed . Finally
Old Mar 22, 2012 | 07:19 PM
  #51
mongorat427's Avatar
I read that the spoilers used on the 70 thru 81 firebirds actually work very good. Its just a simple blade style. Picked one up cheap off ebay to mess around with
Old Mar 24, 2012 | 11:48 AM
  #52
Anyone have a trunk lid lying around ?
Old Mar 24, 2012 | 11:54 AM
  #53
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by slowswap
Fixing the rear spoiler is an excellent first step. It doesn't create downforce from factory....
what do you mean? it provides a whopping 144 lbs of downforce and turbulence at 155mph
Old Mar 24, 2012 | 12:36 PM
  #54
conerboner's Avatar
I have my stock trunk but its black and shipping wouldn't be cheap. i like the way the splitter looks. the g5 rk sport rear lip kind of has diffusors on it bit the vortex generators are definitely cheaper
Old Mar 25, 2012 | 04:15 PM
  #55
BlkWdoSS's Avatar
You all are referring to the lil black plastic strip that hangs down by the radiator as the air dam? If so, mine has been off for 5yrs without issue... I get ~185-189 coolant temps at cruise
l8r,
PD
Old Mar 25, 2012 | 04:16 PM
  #56
l8r,
PD
Good to hear
Old Mar 26, 2012 | 10:21 PM
  #57
madcitySS's Avatar
I like that. Always want to make stuff like this but the classes I run I can't use them lol.
Old Mar 27, 2012 | 02:20 AM
  #58
BlkWdoSS's Avatar
Originally Posted by mongorat427
Good to hear
yea as long as I was SC I NEVER had any issues with overheating. Even sitting in hours of traffic the car would get to mid 190s max. I think you will be ok removing it.
l8r,
PD
Old Mar 27, 2012 | 11:00 AM
  #59
RoadconeTuning's Avatar
l8r,
PD
my buddies ion redline would get HOOTTTTT if you were cruising over 70 on the highway without the airdam, after 70 it would kill the fans and i guess the ions airflow wasnt the same as the cobalt.
Old Mar 28, 2012 | 02:00 AM
  #60
BlkWdoSS's Avatar
was he running an aftermarket heat exchanger or the stock one? after checking out sum stuff around here I can see most of the overheating issues that some had couldve been linked to having an aftermarket heat exchanger in front of the ac condensor.
l8r,
PD
Old Mar 28, 2012 | 09:21 AM
  #61
some sort of aftermarket...
Old Mar 29, 2012 | 04:05 AM
  #62
BlkWdoSS's Avatar
yea, thats about right. The aftermarket ones block the main passage of air in the front. That could def be the cause of it all.
l8r,
PD
Old Mar 29, 2012 | 08:02 AM
  #63
Powell Race Parts's Avatar
No air dam leads to cooling issues.
Old Mar 29, 2012 | 08:30 AM
  #64
Hi John what angle is you blade spoiler set at ? And how High should I go ?
Old Mar 30, 2012 | 03:58 AM
  #65
BlkWdoSS's Avatar
I understand how it can lead to cooling issues. I do not understand why mine hasnt had those issues as others have. I live in Texas so it gets very hot here.
l8r,
PD
06MetallicBalt
Jul 20, 2025 08:47 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
Trav3480
Sep 28, 2015 02:46 PM
