Harnesses for better holding
After a day at the track I realize my shoulders are sore from holding on to the steering wheel and my left knee has a nice bruise on it from bracing myself. Without replacing my seat and installing a roll cage, is there a harness I can get that will keep me held in much tighter to the seat? I've seen some folks with systems that bolt onto the existing seat belt points and then the over the shoulder straps either click into the rear seat belt buckle or child safety latches. Does anything like this exist for the Cobalt? I've looked around and found some things that *might* work but was wondering if anyone out there has done anything that is proven to work?
First make sure your side bolsters are holding you well. You can bend them inward to help hold you. Also verify your seating position is correct for racing (there are a number of guides out there that all pretty much say the same thing, Porsche does a nice one on Road & Track).
Best option for stock seats: https://www.schrothracing.com/products/quickfit
What seats do you have? Reason I ask is that the stock seats in my (2010) SS hold me just fine at the track (pulling 1.2G's) in concert with the stock seat belts.
I have to get on my soap box for a minute here and talk about safety. There are road safety systems (3-point belts, collapsible seats, airbags) and there are race track safety systems (5 point belts, rigid seats, roll cage and helmet) and you can't mix and match between the two. While the seat belts linked by Foximus may be fine for autocross, where speeds are low and a rollover is highly unlikely, I would not use them around a race track, let alone for street driving. In a rollover crash, they will not allow you to slide down and forward the way a road safety system is designed to do, putting you at risk for neck injury/paralysis from the collapsing roof.
I know some folks use a so-called CG Lock which basically straps you in at the hips to keep you from sliding. I have the same concerns listed above about those at a race track though.
Here's a really good article about safety systems:
https://www.thetruthaboutcars.com/20...-safety-facts/
Where Would You Like Your Sperm?
Yet if I needed to pick one-- I guess it's just my biological wiring-- I am most excited for blowing my lots deep inside her *****. I intend to be so deep that her external lips rest on the actual base of my dick, and her inner walls hold the whole length of my shaft. With every square inch of my member wrapped up in her ****, I 'd fill her up even more with a significant lots of orgasm, my sticky ropes firing off deep right into her smoking cigarettes warm ***** ... That is where I'm most eagerly anticipating my *** to go.
https://24.torayche.com/index/d1?dif...tm_term=&site=
https://www.hungryhobo.com/?URL=http...dsexvideo.org/
https://www.artstor.ru/bitrix/redire...dsexvideo.org/
http://alta-energo.ru/bitrix/rk.php?...hdsexvideo.org
https://bc-nark.ru/bitrix/redirect.p...dsexvideo.org/
https://3.caiwik.com/index/download2...hdsexvideo.org
External Redirect | WW2Talk
https://hosted.mo1send.com/6ESU?doma...oice%20Surveys
https://wiki.reformrivers.eu/api.php...dsexvideo.org/
https://53.pexeburay.com/index/d1?di...dsexvideo.org/
https://wiki.btguard.com/api.php?act...dsexvideo.org/
https://svetlica-home.ru:443/bitrix/...dsexvideo.org/
https://www.e-deal.com/ed/solicitati...org&name=merck
Making Chat Links Within the Neighborhood
I have actually been visiting MarriageHeat for regarding a year now, and I simply wish to start by saying exactly how happy I am for this room. The honesty, susceptability, and party of God-honoring intimacy in marriage has been both encouraging and rejuvenating. The tales shared here have actually often stirred something great in me-- occasionally motivation, in some cases wish, and often just the calming feeling that I'm not the only one in what I really feel or wish for.
https://lundenilona.ru/bitrix/redire...lsexvideo.org/
https://en.grplan.com/member/login.h...lsexvideo.org/
https://embed.notion.co/api/iframe?a...811dca7919d483
http://www.gavgav.info/catalog/redir...lsexvideo.org/
https://belo-horizonte-minas-gerais....lsexvideo.org/
https://cart.thomasnet-navigator.com...lsexvideo.org/
https://wiki.noah-ruben.de/api.php?a...lsexvideo.org/
https://minfin-altai.ru/bitrix/redir...lsexvideo.org/
https://web.itex.ru/bitrix/redirect....lsexvideo.org/
https://wiki.flowenergy.com/api.php?...lsexvideo.org/
Redirect
https://63.cepoqez.com/index/d1?diff...pushMode=popup
http://myblogersi.blogspot.com/search?q=fullsexvideo.org| fullsexvideo.org | http://myblogersi.blogspot.com/
https://shespuah.com/member/login.ht...lsexvideo.org/
https://thethermograpiclibrary.org/a...lsexvideo.org/
Redirect
Powell Race Parts
88
Apr 8, 2014 09:53 AM
