New cooling mods: Vented hood and trans cooler
Your statement would be much more pronounced if you included a picture of your certifications hanging on the wall.
The entire reason air flows through the radiator is because there is a high pressure area on the outside side, and a low pressure area on the inside side. The air flows through from the high pressure to the low pressure side, and then out through the low pressure area under the car. That's the main point of the air dam under the radiator, to help increase the high pressure area in front of the radiator and increase the low pressure area behind the radiator. It helps draw the air through the radiator, rather than straight down to the under car low pressure area.
The cowl may have a high pressure on the outside, but it can help draw cool outside air IN to the engine bay, and out through the low pressure under the car. Hence the name cowl INDUCTION.
The vents he wants to install are in a low pressure area where they will function.
Your statement was directly aimed at a cowl at the hood-windshield not functioning because it is a high pressure area. But okay, you're obviously way too smart for my feeble mind to comprehend.
Courtesy of: mechanics stack exchange
While I won't say a cowl was never used for cooling the engine bay (I'm sure someone has done that), it really won't do much for cooling (as in to draw air out from and engine bay) and here's why:
As your vehicle is travelling down the road the air travelling around different parts of the vehicle creates high pressure areas. The two biggest of these are the front end (grill area) and the windshield. The base of the windshield especially, because this is where the air starts to make its turn upward to go over the top of the car. Because of this, there is basically no way for there to be any heat extraction from this area. You can, however, draw air into the engine from there. This high pressure area not only provides a source of denser air, it also provides cooler air, all of which helps produce horsepower. This was GM's theory behind the Chevelle Cowl Induction hood.
There are three main purposes for a cowl hood:
Aesthetics
Provide clearance for under hood engine parts
To locate a source of cold air for the intake at the base of the hood
If a manufacturer has wanted cooling effects from the hood area, they will usually use an extractor to do this. Heat extractors work by using the venturi principle, where the air is sped up over a lip and when it gets over the lip, it slows down and creates an slight vacuum at the port, which pulls air out from under the hood.
My point was you do not extract air out from under the hood by lifting the rear of the hood up or by leaving your wiper tray out. What the OP is doing will work best for his purpose. Looking forward to the finished results.
That's not my drawing... Plenty found via google if it matters.
"As your vehicle is travelling down the road the air travelling around different parts of the vehicle creates high pressure areas. The two biggest of these are the front end (grill area) and the windshield. The base of the windshield especially, because this is where the air starts to make its turn upward to go over the top of the car."
Empirical data would be more like a picture of a Cobalt in a wind-tunnel with relative pressure indicators under the hood and at the back of the hood where I am asking about. If the flow is laminar enough it might be an area of "higher" pressure relative to the rest of the flow around the car but it only needs to be lower than the pressure under the hood. If you see all the red arrows at the front of the car in your very generic oversimplified graphic, you can imagine what the pressure under the hood may be. Do you have any actual empirical, as in measured in real life scenarios, data that shows the differential pressure between the cowl location and under the hood in the same area on a Cobalt? If not than you don't have what I'm looking for you just have generalizations.
Edit: Btw, not saying the theory is wrong, I just like to see real data. After searching it looks like the only way to get that is to gather it myself. Looks like a quick experiment with some strings, tape and a go-pro would do it.
