Superchips Tune
Superchips Tune
So I am currently trying to find out a little information for classing reasons.
I currently run in DSS (Canadian). I have an allowable 6 points. my current set up is:
Pedders Springs: 3 Points
Rear Sway Bar: 1 Point
So I run the Superchips tune off the track and flash back to stock for autox. I recently competed in DSP with the tune, and I love running with the tune (Almost had an FTD with it tuned). It is the perfect amount of power. I want to know if the superchips tune works the same way as the GMS1. There has been many discussions on how it does not alter the boost directly. I will be dealing with the same issue if I want to run the tune.
8.8.2. Alternate ECUs /chips may be used on normally aspirated vehicles. Alternate
ECUs/chips may be used on forced induction vehicles only if the ECU/chip does not
DIRECTLY alter boost settings. Turbocharger boost settings may not be
specifically altered.
My plan is if it does not alter the boost directly I will run the following set-up to see how it works:
Tune: 4 Points
Fire Extinguisher: -1 Point
Not sure how the car will react without the rear sway bar but I am interested in the different set up.
So, does the superchips tune directly alter boost settings? What are others set-ups in DSS?
Tune: 4 Points
Yes..
link:
Superchips Programmer new boost level - just about 20-21 psi
https://www.cobaltss.net/forums/show....php?p=5073380
Thanks for the reply ronn.
Just because the boost is raised with the tune doesn't mean the tune directly alters the boost though. GMS1 does not alter thr boost directly but you still see higher numbers. So I am hoping superchips is the same
Sorry I think your logic is a bit flawed there. Most (if not all) tunes directly affect boost settings. Stock is 12-15 psi and no matter how hard you try to argue semantics, Superchips, Trifecta, etc all raise boost to 20-30 psi. This DIRECTLY affects boost settings and if you talk with an official, they will tell you the same thing. If you however find a way to have boost hit earlier and give you maximum power with the same pressure at lower RPMs, then you would be fine.
We had this discussion a while back. The argument is that with any LNF tune you don't DIRECTLY alter boost. You change the desired airload.
It's a stretch but not any further than people running R-comps as "street tires". I decided not to run a tune for STX. I would kinda feel like I was cheating and around here we never see third gear so I don't really think it would help much.
https://www.cobaltss.net/forums/autocross-road-racing-53/autocross-class-ss-tc-gm-upgrade-198738/
There is the link to the GMS1 discussion for those who aren't quite grasping what I am talking about.
Thank you jboogie, this is exactly what I am trying to get at. I understand that yes it results in higher boost settings, but it is indirectly altering them. So I am wondering if superchips acheives higher boost levels the same as GMS1.
https://www.cobaltss.net/forums/showthread.php?t=198738
I still say if BOOST is increased it doesn't matter! You should take a hit. If you can get away with it..fine...but you're at an unfair advantage over stock boost cars.
It's damn close. You saw 20-21..that's a big increase over stock. That's what I run on my HPT tune and it's more HP (about 20 more) than GM1.
