BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
HID Fog Lights(installing)
Old Mar 24, 2011 | 08:09 PM
TxLonghorn#1's Avatar
Ok, I just received my head lights and fog lights. I got projectors headlights with HIDs for the normal head lights and for my brights. My question is the box had 3 harness inside, does anyone know if I suppose to use 1 harness for each set of HIDs? I can't figure out if the fogs need a harness, I have my fogs connected to a ballast(2fogs=2ballast) right? I connected the harness to the driver side ballast and I ran the long wire to the passenger side, but since the HID is connected that that ballast, there isn't a connection for the harness wire. So do I need the harness? Thanks!
Old Mar 24, 2011 | 08:35 PM
Turbalt2010's Avatar
you should need 3 wiring harness's one for each hid kit (high beam, low beam, and fogs). the wiring harness will go from the battery to the right ballast and then the other wire will go to the left ballast. you should have the harness going in the ballast and the bulb wiring going out.
Old Mar 24, 2011 | 08:53 PM
but here is an extra connection from the passanger side
Old Mar 24, 2011 | 08:55 PM
if it is the stock headlight harness plug then thats fine. that doesnt go anywhere.
pictures help a lot lol
Old Mar 24, 2011 | 09:23 PM
[IMG][/IMG]
Everything is plugged up correctly(correct me if I'm wrong) but that blue to the far right is from the harness and that's plugged into the ballast. The stock wire is the one with all the tape, at the top, taht's connected. and the two small wires from the ballast are connected to the two small wires from the HID. now that leaves the one yellow connector(too the far left without being connected to anything. Anyone know?
Old Mar 24, 2011 | 09:27 PM
bbrewbaker's Avatar
That will plug in to the ballast.
Old Mar 24, 2011 | 09:30 PM
^^this would be considered a HID single xenon install correct? I looked at the how-to from buyHIDS.com and it doesnt show a harness. Can anyone help me out please?
http://buyhids.com/pdf/install_single_xenon_kit.pdf
the ballast has the plug from the harness from the driver side already there.
Last edited by TxLonghorn#1; Mar 24, 2011 at 09:30 PM. Reason: Automerged Doublepost
Old Mar 25, 2011 | 02:46 PM
mkulrey13's Avatar
If your using a relay harness.. You do not use those plugs on the passanger side. Its controlled by the driver sides harness.. Relay provides power to the ballast so you do not need to have your harness plugged in as you are not getting power from it.. Its plugged in on the drivers side for the switch aspect of it.
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
z28addiction
Sep 28, 2015 12:03 AM
