Manitoba SS 2014
#3254
Well what is there really left for you to buy you basically own the full zzp catalog
#3257
Yeah my car takes a while but it gets to temp. Must be somethin off.
Perhaps that f40 takes it a little easier on clutches due to the closer gear spaceing and more preferred final drive
Last edited by slapbetcommissioner; 12-01-2014 at 10:07 AM. Reason: Automerged Doublepost
#3272
Most ecotec clutches are rated really goofy and low. My current clutch is rated at 250 ft/lbs from what I've found. I've thrown a sustained 450+wtq at it quite a few times and its never slipped. It's also the highest rated and strongest clutch available. I think I'm going to put it on the shelf until mine slips unless winter gets stupid long. Mine feels like stock right now and with the big dual mass flywheel its silent at idle with the clutch out, and it only has 6k miles on it, but when it goes I am covered!
#3273
Well dammit my boost sensor blew today. Guess it was on its way out or it froze to often. Did everything to try to make it stop, nothing worked. Guess replacement will be moved to warmer place under the hood. And I need new oil pressure sensor to, yay.
