Manitoba SS's 2012 thread
Old Aug 23, 2012 | 01:39 PM
  #3801
Bluelightning's Avatar
Got Bewst?
Originally Posted by Projekt
Noobs. Like Tstone.
Why put all that work into your car and not upgrade the clutch???
Why? Because RACECAR
Old Aug 23, 2012 | 01:58 PM
  #3802
yellow dragon's Avatar
Old Aug 23, 2012 | 02:04 PM
  #3803
Projekt's Avatar
Yeah its got a full tank of gas!
Sooner eh. When are you planning on selling your headlights? ill need them untill i get the shipment from Mrukley because i start work on sept 4th when ill be driving to work everyday
Other Dustin, Bulk Barn, 5.79 a lb for natural almonds, coupon in the flyer to save 3 dollars off a 10 dollar purchase.
Boom two lbs of almonds for like 8 bucks.
Old Aug 23, 2012 | 02:06 PM
  #3804
slapbetcommissioner's Avatar
LOL nice deal.
I was hoping to sell them starting this weekend. Need CA$H!
Order those parts!
Old Aug 23, 2012 | 02:10 PM
  #3805
Projekt's Avatar
I honestly cant afford them till the 31st.
Old Aug 23, 2012 | 02:14 PM
  #3806
Credit card that Shizit.
Fine i will wait.
Old Aug 23, 2012 | 02:35 PM
  #3807
Injectors are ready!
Old Aug 23, 2012 | 02:36 PM
  #3808
And there was nothing wrong with them?
Old Aug 23, 2012 | 02:42 PM
  #3809
He didn't say I will ask when I pick them up.
Old Aug 23, 2012 | 02:43 PM
  #3810
Projekt's Avatar
lol. you didnt think of asking?
Old Aug 23, 2012 | 02:48 PM
  #3811
I am at work and the boss aint fond of people on the phone. So I knew I could ask when i went to pick them up. Also seeing they are ready for pick up I assume they were good otherwise they would have called and said they are screwed can we order you some.
Old Aug 23, 2012 | 02:49 PM
  #3812
Projekt's Avatar
Well you were hoping they were broken.
Old Aug 23, 2012 | 02:51 PM
  #3813
True
Old Aug 23, 2012 | 02:55 PM
  #3814
Got Bewst?
Or one of them atleast.
Old Aug 23, 2012 | 03:01 PM
  #3815
Boss isnt fond of Phone calls. how does he feel about swapping injectors?
Old Aug 23, 2012 | 03:02 PM
  #3816
Projekt's Avatar
Mike, I took this from ZZP's site, Its a good read.
KR is a result of detonation. To have ‘real’ (more on ‘real’ vs ‘false’ KR later) KR, you MUST have detonation. Detonation is the uncontrolled combustion of the intake charge. “Uncontrolled” means that the mixture ignites via a means other than the spark from the spark plug. In most cases, the uncontrolled ignition is due to a ‘hot spot’ in the cylinder. Hot spots can be caused by uneven combustion, spark plugs that are rated too ‘hot’, lean fuel conditions, breathing restrictions (exhaust / intake), bad gas and so forth. One problem in particular that came to light for me was the head gaskets. During one of my engine teardowns, Zooomer from ZZP pointed out that, while my cylinder bores are perfectly round, the head gaskets are NOT made perfectly round. Some of the gasket material actually protrudes slightly into the combustion chamber. Since the head gasket bore linings are made of metal, that little bit that protrudes into the cylinder glows red hot, thus creating the potential for a nasty ‘hot spot’. This is a good area to check and perhaps replace with an aftermarket head gasket. In other cases, the ‘hot spot’ is due to unreasonably high cylinder compression. Either way, the ‘pinging’ or ‘rattling’ sound you hear is the result of the actual collision of the flame front produced by the ‘hot spot’ and the normal flame front produced by the spark plug. Typically, these two flame fronts are opposing fronts, meaning that they are expanding, or propagating toward each other, thus the collision. Real KR does NOT occur without detonation occurring FIRST.
Old Aug 23, 2012 | 03:06 PM
  #3817
Projekt's Avatar
Mike this could be a stupid question but you are filling up with 91 right?
Old Aug 23, 2012 | 03:20 PM
  #3818
I think he uses big boy gas for his big boy KR.
94Husky Right?
Old Aug 23, 2012 | 03:22 PM
  #3819
Projekt's Avatar
94Husky Right?
Old Aug 23, 2012 | 03:27 PM
  #3820
Just got them back I asked how they were and the guy said horrible. spray pattern was real bad. so they fixed them up and are good to go.
I use and always have used 91 Octane. Usually from Red River Co-op. Every 3rd or fourth fill I use shell Vpower.
Old Aug 23, 2012 | 03:29 PM
  #3821
Projekt's Avatar
Perfect! this will hopefully help your problem. Who did you buy the 60's from? was it zzp? i was send them a email with the test and tell whoever you bought them from that they were fucked
  #3822
Well thats good new mike! a **** tacular spray pattern would definitely make it hard in the high rpms!
you should throw a tank of 94 in if that doesnt fix it. I realize your timing is turned way the **** down right now though.
Old Aug 23, 2012 | 03:31 PM
  #3823
Projekt's Avatar
It wont do anything unless his tuner tunes him for 94 (e10)
Old Aug 23, 2012 | 03:36 PM
  #3824
I realize that. Unless its combusting as is. it could only help..
Old Aug 23, 2012 | 03:37 PM
  #3825
I have my fingers crossed this helps I will install them after work. GIggity.
