Manitoba's SS's 2010
#526
YTou'll have to balence cost of purchase with install, versus how long they would last when buying used, but there are deals out there.
you can do:
- 215/45/18
- 225/40/18
- 235/40/18
and still likely have zero discernible speedometer error
I am currently running Kijiji-special Continental Winter Contact 790's @ 225/45/18, and am not worried about the minimal speedo error...
#527
The best deal I could find (quite a bit cheaper than TireRack) was Discount Tire Direct. They have free shipping in the US, and free mounting and balancing. I just shipped to Menke's and picked them up myself. Ended up getting 17" Drag DR-34 wheels and studded 225/45R17 Hankook iPike's
#528
1 Post
Discount tire had a deal on falken winter tires, 18's for 135 a tire.
Personally, since you have a ss/sc i would get 16 inch steelies and run a 16 inch winter tire
i snagged some 235 winter tires in 18s off of kijiji for 100 bucks
#529
Bridgestone Blizzak WS60
Bridgestone Blizzak LM-60
Bridgestone Blizzak LM-60 RFT
I realize none of this are the exact size you wanted but I don't see any in that size
#532
195or 205-50or55 r16
They will be off by 2% one way or the other for diameter.
I wouldn't suggest putting 18s on the back If you have 16s on the front or vice versa it could cause allignment issues. Did you have blizzacks as summer tires?... Speedo shouldn't make a significant difference if you do though.
#538
Het mike I hope the interceptor install went ok. Sorry about not having the instruction sheets. I lost/misplaced alot of **** during the move to my house. Let me know how you make out. I think you'll like it it's a nice piece.
I still have a factory airbox with a k&n used for prob 1k. Anyone lookin??
#539
Got Bewst?
#540
Thanks for the help dude!
Last edited by yellow dragon; 11-04-2010 at 09:20 AM. Reason: Automerged Doublepost
#545
I realize I've asked already, but anybody here have an oil pan heater?
I haven't had time to get under the car and measure what size of heater could attach to the oil pan yet.
#548
First year it's been winter driven, I definitely want to put some kind of heat under this thing for a cold Winterpeg winter!
#549
1) it's not the driving part that requires heating - it's the possibility of the coolant freezing/ and expanding, and the risk of cracking a block that requires the heating. So even if it wasn't winter driven, if it wasn't in a heated garage, it would have been subjected to the same freezing temperatures...
2) last time I checked, Winnipeg and Calgary have the same lows - but you guys have it stay in a deep freeze there for expended periods, whereas here it's a constant cycle of warming & cooling...
#550
two facts;
2.) Average min. temperature in Winnipeg in January of 09: -25 degrees
Average min. temperature in Calgary January of 09: -12 degrees
Winnipeg winter's are wayyyy colder!
