Water Meth = 100 RWHP Gain!
Old Jul 24, 2006 | 09:47 PM
meister's Avatar
I know it is not a Cobalt, but it just proves this stuff works. We have been using snow's kit for years now, and that is why we are the biggest snow dealer in Canada. You CANT spray a roots/twin screw car the same way as a centrifugal or n/a car because it needs to be in boost to work properly
Spent some time tuning a car today...
2000GT
Ported Heads
Crower Cams
T-Trim @ roughly 20psi
Water Meth.
Kooks LT Headers
Tuned the car without water meth first, as that is the proper way to control fuel...cant just tune a maf transfer function with the meth spraying. The inlet temps were an insane 203* and the car made 438rwhp because of the inlet temps are low timing
Added the water meth, tweaked the air fuel and timing to where it should be and we picked up over 100RWHP, over 60RWTQ and the inlet temp's dropped to 101*F
We could not get a good tach signal out of the car so it was tough to get adead ccurate numbers.
Preliminary results:
Pump Gas, 11.0 AFR, low timing = 545RWHP
Race Gas, 11.8 AFR, Mild Race Timing = 600rwhp
Old Jul 24, 2006 | 09:51 PM
03gobluecobra's Avatar
wow, those are some very hot inlet temps. Excellent tuning work.
Oh, and any chance you steeda boys are going to start making some cobalt parts?
Old Jul 24, 2006 | 10:09 PM
meister's Avatar
hot temps are common for big boost and no intercooler.
Old Jul 24, 2006 | 10:14 PM
player_1's Avatar
wow, that's mighty impressive.
can't wait to come down for you to tune my car
any news on the software yet. I'm going to try yto have my exhaust finished before I show up.
Old Jul 25, 2006 | 12:01 AM
distillion's Avatar
my wallet will be ready a week from this wed for tuning, cant wait,
meister i have a question, after you tune my car, weve discussed that mine will be fairly easy, and if i wanted to swap to a 2.7 would it need to be tuned for that pulley or is the tune im getting enough to compensate?
also if i did swap, would 60lbs fuel injectors be necessary?
Old Jul 25, 2006 | 12:45 AM
player_1's Avatar
oo oohh Mikey are you starting to get tuner feaver
sound to me like you wanna spend more shinney pennies.
guess what, I just got my Billetflow pulleies today, they look awesome.
Old Jul 25, 2006 | 07:05 AM
distillion's Avatar
^^^lol, if i were to do that, it would be one of the last things i do regarding performance
Old Jul 25, 2006 | 08:40 AM
player_1's Avatar
actually I think water meth is a great mod, it allows you to do so much more to the car then without.
I've just never liked the Idea of spraying before the blower.
I've always thought that after the blower is the proper way to do it.
Old Jul 26, 2006 | 08:32 AM
meister's Avatar
We spray after the blower with centrifugal blowers and Roots/PD blowers and turbos. You CANT spray before the blower on these car's because the meth will not atomize, nor will it be in boost so the hot temps will not drop as they should.
You want to tap the manifold/below the blower for this to work properly...this will also keep the meth off the blower rotors.
To run meth properly under the blower, you need an upgraded solenoid from snow. Because manifolds, or anywhere after a TB has vacuum, it will suck the meth into the intake at idle, etc. The upgraded solenoid prevents the meth from being sucked into the engine while running under vac. conditions
Old Jul 26, 2006 | 08:33 AM
meister's Avatar
im still waiting for hp to send out my software..not sure what is taking so long
Old Jul 26, 2006 | 11:20 AM
player_1's Avatar
this is exatly what I've been trying to tell people, who are spraying pre-blower. WTF is the point, sure it works, but your trying to cool ambiant air as it's about to be compressed.
spray after the blower, and your cooling hot compressed air. which is the whole point of spraying.
the only real benifit to spraying pre-blower that I see, is it helps keep the temp of the blower housing cooler (to a a degree), but to what expense, risk damaging the blower, or washing the bearings of the impelers out (increasing friction).
just always gave me a bad feeling, others can do what they like, but I plan on keeping my car for a vary long time, and I want it to run perfectly as long as I can.
which is why I'm upgrading internals and not pushing them to the max.
as far as the Program goes, it's OK that we have to wait.
I'm still waiting on my Full back exhaust from JBP coming mid Aug.
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
