Devil's Own install Ques
There should be instructions with the kits? are we leaving them out? Let me know so i can get onto the person who boxes up the orders.
green wire goes to the map sensor.
https://www.alcohol-injection.com/in...rn_redline.pdf
OTT Performance is running a group buy for your water meth kit, its specified for the cobalt and ion (supercharged), i have an 08 turbo cobalt. I want to inject based on boost, not MAF/MAP. Will this kit do that, or is it nonfunctional without being wired to the MAP? Also, will the low level tank switch, not the float switch, fit within your 2 quart tank? i don't have and can't find specs on the length to determine if it fits. THANKS
Map sensor is what reads boost. We do have a new controller with a internal map sensor coming out latter this week, It will be a tad more expensive, but will make it where you can cut a boost line put a tee in it and run it to the controller vers taking a posi lock and using it to tap into a wire.
Delta coupe
Sep 30, 2015 08:11 AM
