DevilsOwn Alcohol Injection DevilsOwn Alcohol Injection is a Supporting Vendor of cobaltss.net
Contact: devilsown
Devil's Own install Ques
Old May 13, 2008 | 06:16 AM
XbandiniX's Avatar
Does the check valve screw direcly into the nozzle Holder (the 90) ? This is the only way i could see it being.
Old May 13, 2008 | 07:35 AM
2K5SS/SC?'s Avatar
Yes!
Old May 13, 2008 | 03:52 PM
XbandiniX's Avatar
Thanks
Old Apr 21, 2009 | 10:59 PM
startingline05's Avatar
I have the progressive control and i have no idea where the green wire goes to.... help please....
Old Jun 19, 2009 | 10:05 AM
devilsown's Avatar
There should be instructions with the kits? are we leaving them out? Let me know so i can get onto the person who boxes up the orders.
green wire goes to the map sensor.
https://www.alcohol-injection.com/in...rn_redline.pdf
Old Jun 20, 2009 | 07:52 AM
hiltu's Avatar
OTT Performance is running a group buy for your water meth kit, its specified for the cobalt and ion (supercharged), i have an 08 turbo cobalt. I want to inject based on boost, not MAF/MAP. Will this kit do that, or is it nonfunctional without being wired to the MAP? Also, will the low level tank switch, not the float switch, fit within your 2 quart tank? i don't have and can't find specs on the length to determine if it fits. THANKS
Old Jun 20, 2009 | 08:47 PM
devilsown's Avatar
Map sensor is what reads boost. We do have a new controller with a internal map sensor coming out latter this week, It will be a tad more expensive, but will make it where you can cut a boost line put a tee in it and run it to the controller vers taking a posi lock and using it to tap into a wire.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
