2009 LSJ/LNF Throwdown Competition
no. too "underrated" for what i'll need.
i will next time i'm up there, two weeks maybe? thats what i'm getting anyway, the stage3 hypersuperduper single ladiesbring my milkshake to the yards
is that what that picture was of that you sent me? i was outside and couldn't see the screen very well, and then just never checked it again hahah
you're thinking of the spec clutches
Last edited by EXsoccer1921; May 1, 2009 at 12:26 AM. Reason: Automerged Doublepost
are these "right people" you?
what clutch are you using drew???
and yes trav. these "right people" could just possibly be me and my friend with the z28 and another friend with a lift across town. but hey....then again it may not be
its the stocker. that was for clutch and flywheel, so my clutch and flywheel only have 11k miles on them so thats y i havent bothered replacing it for one that can handle more power, mine as well have this one completely go out
i'll probably call you or text you for some tips though during the install travis. i had to make a couple calls to bryan with the mounts hahah. damn bastards wouldn't work
drew is the b woody upper a true solid mount? got any pictures?
Last edited by EXsoccer1921; May 1, 2009 at 12:59 AM. Reason: Automerged Doublepost
that works, just give me a call. really its an easy process just time consuming. oh and when you replace the TOB carefull cause the torx bits that hold it on are real soft, we about stripped the **** out of one.
idk wat u mean by true solid mount? its one piece
http://bwoodyperformance.com/product...products_id=46
i only have the engine mount not the other mounts
