Drag Racing Kindle Racing and Dalcorp Racing
Anyone under 14 sec I need you
Old Jan 13, 2007 | 02:31 PM
  #101
SilverSS/SC's Avatar
Originally Posted by Cobalt_Supercharged
To cool the air yes, but you have to cool the fluid back down or have more fluid to absorb the heat. Trust me, one of the guys in AZ was using the the 2.5" with the stock HE and would heat soak by about the 1/8th-1000ft. His top end suffered pretty bad and people with Intense Stage 3 would catch up.
On my buddy Mikes 93 Z28 ( F1 procharger , FM heat exchanger /rear trunk mounted fuel cell ice box and high volume pump , 383 656 RWHP/570 RWTQ ) , were eliminating the intercooler all together and gonna soley use the water injection because it works so well . Another local high HP car did this with great success .
Unless your using ice water the water injection will cool down the air much more efficiently than the stock SS heat exchanger or 2 of them piggybacked .
Old Feb 26, 2007 | 05:54 PM
  #102
outtamymind's Avatar
Thumbs up
just wanted to say that for a beginner for me you guys are giving excellent advice and tidbits. thanks and keep them coming
Old Feb 27, 2007 | 07:57 AM
  #103
Turbo Wax's Avatar
Up Date
And The Saga Continues for us
So far on one of them we have installed
Axles
Solid Mount ( what pieces of garbage the car shakes like a Mack Truck)
ECU
Bigger Injectors
Changed the pulleys AGAIN
the exhaust should be here any day
So far the BEST time 14.07 with our Pro Driver, we will try with the drag radials and the exhaust and I think that be the end of the road for us with the Cobalts.
Old May 21, 2007 | 03:07 PM
  #104
R33P3R007's Avatar
360 L337 User
i say invest in a stage 3 driver mod.
Old May 22, 2007 | 02:03 AM
  #105
Asphalt Assault's Avatar
Originally Posted by Turbo Wax
Up Date
Axles
ECU
Bigger Injectors
I agree.. I went faster with stock everything, then bought GMS2 and put in a drop in filter to get 13.9. My point is I did this on 10 runs and I am not a professional driver. I am a Registered Nurse.
Old May 22, 2007 | 03:47 PM
  #106
bojan's Avatar
Originally Posted by djt81185
Here is what I would recommend
Intake (largest Possible piping diameter)
60lbers
2.4" from ZZP
ZZP machine Tool
Some sort of header with 3" outlet to a 3" d/p and full 3" exhaust (no neckdowns anywhere) straight thru mufflers and resonators NO BAFFLES...No cat if i can get away with it
Air Ride Air Springs
Exedy 6-puck clutch/flywheel combo
DSS Stage 2 axles
Shave brake calipers to clear 15" wheels and run full on slicks
Devil's Own Progressive Alky injection Kit
Stage 2 belt
Intense 3" tensioner
Sparkplugs intense sells
Intense Trans axle mounts
Dual Pass i/c conversion
I see no reason why this wont go 12.5 on pump gas with slicks
Dan
if i had extra $ i would do this mod list
Old May 22, 2007 | 04:00 PM
  #107
chevysalesman614's Avatar
Some of you may or may not know that we have 2 Cobalt's SS 06s, so far we had nothing but bad luck with them, in our first attempt at the track out of the hole @ 3,000rpm the left axle snap, on our second attempt the belt tensioner broke, with that said I'm getting very frustrated with my Cobalt's. our best time so far is 14.50 on street tires spinning all over the place.
I will like to know a few things from all of you, I need the cars to be @ 12.50 or better, so my questions are,
What Mod could you guys suggest to get the power needed to that level.
What Clutch are you guys using ? has the stock clutch be good to you ?
What have you done in the axle dept ?
Any help could be greatly apprecciated.
i realize that I'm posting way late in the discussion, but i think your best bet would be limiting the boost alot in first gear. mine is at a max of 10psi, but mostly at 8. still running stock axles, and clutch. and tires. my only traction mod to speak of are the ssc springs, (installed tomorrow morning @ 8:30). but at the track I've had minimal wheel hop issues. (i usually let off on the first hop, then quick punch it. it grips right up for me.)
p.s. mine is a non G85 model. i guess a good LSD would be an idea for smoother launches.
hope that helped. although it probably didn't
X10000... sounds to me like your guy needs some more wheel time in the car. it's no easy car to launch consistently. lower the boost in first gear. thats really all i can say.
I've got about 30 runs a the track with mine now, so I'm getting comfortable in it... plus I've put 17K on it. I think he just needs to get used to it. Driver mod is a must with these if you really want to hit 12.5. thats the goal for me as well.. although my parts list is way shorter than yours i think.
what I've got so far:
AEM cold air intake, 2.5" magnaflow catback, #42 injectors, 2.9" pulley, dyno tune, ported blower.
installed tomorrow morning:
ZZP header downpipe combo, ssc springs, and NGK 1 step colder plugs.
not too distant future:
Nitrous Oxides Systems 35-60hp wet shot, ARP head studs, stage 2 axles, undecided clutch, torque damper, undecided tires, AEM wideband, BOOST RESTRICTIONS REMOVED.
I'm confident I can get at least a 12.8 right there. but then I've maxed out the engine, and have to do internal work to go faster.
Last edited by chevysalesman614; May 22, 2007 at 04:11 PM. Reason: Automerged Doublepost
Old May 22, 2007 | 04:22 PM
  #108
RuSSo-29's Avatar
Best mod ever!!!!
Old May 22, 2007 | 04:35 PM
  #109
Up Date
Axles
ECU
Bigger Injectors
what pullies and injectors are you running?
Old May 24, 2007 | 09:14 PM
  #110
tityrous's Avatar
lol sorry to say but ur pro driver sucks... better off doing it urself if thats the case!
HeartBeatKid
North East
Mar 1, 2006 11:39 AM
HeartBeatKid
Drag Racing
Mar 1, 2006 11:38 AM
1BADSS/SC
Jan 12, 2006 10:34 PM
Jmc007
Jul 30, 2005 02:09 PM
chevySSfreak88
Jul 11, 2005 12:41 AM
