Best dragstrip techniques and tires.
the secret to fast times in a stock turbo ss/tc is like what ppl said what rpm you shift at. 1st to 2nd i would say about 5800 because the tach cant keep up and ur actually shifting around 6k. nls 2nd to 3rd at 6000ish and nls 3rd to 4th early around 5600. pm slowstang on here, he ran a 13.56 with a stock ss/tc and i remember him explaining how he did it in another thread.
oh and also like 21-23 psi front and 40 in the rear
13.4@104.1 2.07 60ft On GM3+Trifecta Options with BYT Tune
2.9, 42's, 3' Catless DP, Injen Intake
70ish Degrees Outside with similar humidity
Pirelli Pzerro Nero Street Tires 21-22psi
2k Launches Shifting at 7k
Lowest 60ft On street tires: 2.003
Drop the clutch at 6500rpm, run out each gear to 7800rpm, cut 1.7 60's all day like a boss.
Thats my method...seriously.
Obviously that won't work for you, so just follow what those guys said above, good advice there!
not one of my best runs. but i was able to catch a video of one of my better launches on street tires. this was on a 215/45 kuhmo exsta spt. good example of how to lightly slip the clutch and then get in to it. don't mind the missed shift lol
http://www.youtube.com/watch?v=RBMtXsTeJOA
Well, tonight sucked at the track. I either bogged out or spun with my launches from 2k all the way up to 4k..tire psi was at 27psi and the track was super sticky because they kept spraying down some super glue-like stuff...lol
Weather was 72* and 92% humidity....
I ran a best of(my first run) 13.2 @ 107 with a 2.06 60ft...booooo...the rest os the night was 13.4-14 @ 106-107mph...so, i guess i dont have a 12 second car like i thought.
You prob do. Exsoccer drove my car into the mid or low 8s 1/8 on 13lbs of boost when my best was 9.0 hahahah I can't drive T the strip.. just drive it better. Bogolusahondakiller which is tuned on 23-24 lbs and low timing with very conserve.Tq managmwnt got a 12.8-12.7 spinning in second for a while. I'm sure you can do it
my trap speed is garbage, i dont think i have the power that i was thinking i had..people with a 24psi tune are trapping like 110-114. i struggled to get 107...dunno..my clutch started to slip in third a little on my way home, so maybe its gonna take a dump on me too...
i remember at one of the not so great tracks. we were hitting 9.0s quite a bit. thinking about leaving. and i was just like no f it, i'm gonna go run an 8. bam, 8.68
my 60ft was a 2.0 and my 1/8th was a 8.6 and i still couldnt get better than a 13.2 @ 107
..the rest of my runs were much worse after my first run because of the car bogging out.
I hear if you have the high rise, it lowers your trap about 2mph than what it should be, but still dissapointed in my trap...since my redline is stock 6200, i have to shift in 4th before the finish about 100-150ft...
oh, 1/4 tank of gas too
this was my last run when one of my old friends with his built j32a2 swapped accord beat me..i ran a 13.4 @ 107 and he ran a 13.3 @ 103...
j32 accord vs turbo cobalt - YouTube
