E.T. and MPH goals for 2009
hoping to hit 10's, but who knows
should be close...
hahah i woulda been number 4 on the stock ss/sc list, but apparently a muffler and kuhmo tires adds enough power to be considered nonstock....
Last edited by EXsoccer1921; Dec 25, 2008 at 06:16 PM. Reason: Automerged Doublepost
I agree. No way those mods will garner mid to high 11's. You can obviously drive but I think you're shooting a bit high man. I can see mid to maybe low 12's if you drop your car and a cooling mod for more consistant low ET's.
The GM Stage 1 is a tune, With the DI the stock injectors are fine for just a tune and slight bolt-ons, If you really want a BOV it would be alot easier to go with hard pipes,HeaderS? Do they have an aftermarket mani yet for the stock turbo?...Look at what all it took Hahn to barely dip into the 12's (tune, catback, intake, DR's) Thats also with really good driving..pulled a 1.9 60'. I don't see you shaving a second and a half off of his time with what you listed on street tires.
i meant to put mods so far. there will be more in 09 to put me in the 11''s
and i meant a ppc tune not the gm stage kit tune.
hopefully 12.75 @110mph squirting a 70crank shot on my all seasons.
With some timing retard and a 125crank shot if I can afford an AEM standalone anytime soon, low 12s possibly.
Note: s2k, not a balt.
whats so funny is that the lnf crowd is making and will be making the same mistakes the lsj guys did and still do. keep adding the power boys, im sure thats the best way to improve track times.
why do you call it a "crank shot"
Last edited by hatrickstu; Dec 28, 2008 at 12:22 AM. Reason: Automerged Doublepost
im going to say 12.90s,106,with slicks,my mods are,gm stage 2 ,2.79 pulley (17.5 lb boost) gmpp catback,injen cai,cx heat exchanger.tax refund i will get this ,weapon r header with catless dp,#60s,tune,spec flywheel,spec stage 3 plus clutch.
Break into 11's if I can get traction.
Mods are: Precision SC50 turbo, FMIC setup, Diamond pistons 9.5:1, aft. head gasket, p&p head w 3 angle valve job, head studs, Ferrera valve springs, nuetral balance shafts (redline will be changed to 8k), 272 grind cams, hahn intake manifold, other crap to just cant think off top of my head. will be getting mickey thompson slicks for it w/ stage 2 axles.
I've got some tires picked out once I can find some decent lighter wheels....then I'm gonna lower it(still debating on Sportlines again, H&R's or a complete coil-over kit. That should get me the launches I'm lookin for.
I'm just concerned with the H&R's that I'll either have a horrible daily ride, or have to also replace the struts since its so low and then I gotta figure out which ones to buy that will fit and work on my 09 TC with the H&R's. ???
winning races is more important to me than burnouts at 50.
"traction? traction? we talking bout traction? traction? i mean what are we talking about? traction?"
ill post this for now:
http://s189.photobucket.com/albums/z...rent=Stu12.flv
i must be going down the wrong path...
